Piston blocked without cause
Also this morning, like other time one piston don’t work …
There is not a specific sequence of operations, sometimes I only look the piston without modify it and when I test it the piston don’t work.
Then I open it, I don’t change anything, I save it and so the piston work fine …
I don’t understand …
Edit: some piston are very very simple (push one button, set one variable and turn-on the light)
