Piston calling another piston when running a Logitech Harmony Activity
When in turn an Harmony activity, a piston should run
When the activity starts, the piston doesn’t run.
The piston doesn’t run as expected.
**4) Post a Green Snapshot of the piston!!
9/30/2020, 8:11:24 PM +767ms
+1ms	╔Starting piston... (v0.3.110.20191009)
+97ms	║╔Subscribing to devices...
+104ms	║║Subscribing to Watch TV [Harmony Activity].switch...
+154ms	║╚Finished subscribing (67ms)
+200ms	║Comparison (time) 72684941 is_after (time) 1601506320000 = true (7ms)
+202ms	║Time restriction check passed
+217ms	╚Piston successfully started (217ms)
This piston will only run when Switch 10’s switch changes.
(notice the lightning bolt in the left margin)
Yes that’s what i want. Turn the activity on and run the other piston. I do turn the activity on but the called piston is not running.
What I mean is, something has to turn on Switch 10 before this piston will run…
What are you using to turn on Switch 10?
Side Note:
99% of devices do not recognize a difference between programmatic and physical interactions.
(the general recommendation (for line 20) is to use the default, ANY interaction)
I use my Hamony remote.
Can you please post a Full log showing Switch 10 turning on please?
Trying tonight. I run the activity (switch 10 changes to on) but nothing is logging.
edit: if i change condition #3 from a trigger to a condition ie.: replace the “changes to” to “is” then the piston is called.
Not what i’m after.
IF Switch 10 changes to on
is a trigger, and will execute the piston anytime that switch turns on or off
IF Switch 10 programmatically changes to on
is a trigger, but not reported by 99% of devices
As mentioned before, my advice is to go with the first example (the default)
Sorry, forgot to mention I switched it back to any interaction before I tried again.
I get that the the switch changes to on, it should start the piston which would call the other piston. But I do it change it to with the remote but nothing is registering, nothing is logged.
Hmmm… Are you 100% certain that it started out OFF, and then turned ON?
(IE: going from ON to ON will not trigger the piston)
Maybe post the current piston so I can see if anything stands out?
I wrote a new piston from scratch. same issue.
I do turn the activity off using the remote just to make sure Harmony keeps track on the state.
Nothing gets logged either if I go thru google home.
Couple times the piston started with some delay… 3-5 minutes range. trying to replicate to have some log to show. unsuccessful so far.
That piston looks OK, although it won’t work after midnight, and the TCP does nothing here.
Just to clarify…
Everything I have said in this thread is referring to a (real or simulated) switch turning on or off …
I am not referring to Harmony’s “Activity” turning on or off…
Unsure how this happened… but it started.
+1ms ╔Received event [Watch TV [Harmony Activity]].switch = on with a delay of 50ms
+31ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 10ms > CE
+33ms ║Runtime (37319 bytes) successfully initialized in 4ms (v0.3.110.20191009) (31ms)
+34ms ║╔Execution stage started
+41ms ║║Comparison (enum) on changes_to (string) on = true (1ms)
+42ms ║║Cancelling condition #2’s schedules…
+43ms ║║Condition #2 evaluated true (5ms)
+64ms ║║Comparison (time) 76853490 is_after (time) 1601592600000 = true (5ms)
+65ms ║║Time restriction check passed
+66ms ║║Condition #5 evaluated true (22ms)
+67ms ║║Cancelling condition #1’s schedules…
+67ms ║║Condition group #1 evaluated true (state changed) (29ms)
+69ms ║║Cancelling statement #3’s schedules…
+80ms ║║Executed virtual command executePiston (7ms)
+83ms ║╚Execution stage complete. (48ms)
+83ms ╚Event processed successfully (83ms)
`indent preformatted text by 4 spaces`
Sweet…
The only thing I would double check is to make sure the outside logic turns that switch back off at the right time. (to prepare it for the next trigger)
#15
Thanks for the patience. looks like a bit more time was required for the piston to register the switch was off, about 5 minutes to show up on the log. Once registered off, it works as intended when turning the activity on.
#16
I love the capabilities of the Harmony hub, but I agree, the speed leaves much to be desired…
