Switch activated twice, yet piston only seems to fire once.
Switch should activate once at 9AM and then not again until 30 mins before sunset.
I have setup a piston to open some curtains at 9AM and then close them again at 30 mins before sunset. Curtain movement is triggered by a fibaro FGS-222 relay turning on. The relay is programmed to auto turn off after 5 seconds. At the programmed time the relay turns on and the curtains open. The problem is that on some days about a minute later the relay turns on again and closes them. This had been working flawlessly for months when this issue started to happen so I re-wrote the piston from scratch to use timers instead if firing âif time is xâ. I have not seen any change though.
( 20/04/2019, 09:01:35 +672ms
+1ms âReceived event [Home 2].time = 1555747200000 with a delay of 95672ms
+462ms âRunTime Analysis CS > 240ms > PS > 184ms > PE > 37ms > CE
+465ms âRuntime (40360 bytes) successfully initialized in 184ms (v0.3.10a.20190223) (462ms)
+466ms ââExecution stage started
+468ms ââExecution stage complete. (3ms)
+471ms âSetting up scheduled job for Sat, Apr 20 2019 @ 7:03:00 PM BST (in 36083.858s), with 2 more jobs pending
+482ms âEvent processed successfully (482ms)
20/04/2019, 09:01:07 +246ms
+1ms âReceived event [Home 2].execute = recovery with a delay of 61ms
+95ms âRunTime Analysis CS > 20ms > PS > 39ms > PE > 36ms > CE
+98ms âRuntime (40351 bytes) successfully initialized in 39ms (v0.3.10a.20190223) (96ms)
+99ms ââExecution stage started
+120ms ââCondition #16 evaluated false (7ms)
+121ms ââCondition group #15 evaluated false (state did not change) (9ms)
+124ms ââExecution stage complete. (25ms)
+127ms âSetting up scheduled job for Sat, Apr 20 2019 @ 7:03:00 PM BST (in 36112.628s), with 2 more jobs pending
+138ms âEvent processed successfully (138ms)
20/04/2019, 09:00:52 +757ms
+1ms âReceived event [Home 2].time/recovery = 1555747252756 with a delay of 1ms
+453ms âRunTime Analysis CS > 243ms > PS > 166ms > PE > 43ms > CE
+455ms âRuntime (40365 bytes) successfully initialized in 166ms (v0.3.10a.20190223) (453ms)
+457ms ââExecution stage started
+482ms ââComparison (boolean) true is (boolean) true = true (3ms)
+484ms ââCondition #3 evaluated true (9ms)
+486ms ââCondition group #2 evaluated true (state did not change) (10ms)
+489ms ââCancelling statement #6's schedules...
+14322ms ââExecuted physical command [Lounge Curtain Motor].on() (13828ms)
+14323ms ââExecuted [Lounge Curtain Motor].on (13831ms)
+14328ms ââExecution stage complete. (13871ms)
+14331ms âSetting up scheduled job for Sat, Apr 20 2019 @ 7:03:00 PM BST (in 36112.913s), with 2 more jobs pending
+14341ms âEvent processed successfully (14341ms)
20/04/2019, 09:00:55 +727ms
+1ms âReceived event [Home 2].execute = recovery with a delay of 56ms
+7357ms âRunTime Analysis CS > 17ms > PS > 7303ms > PE > 36ms > CE
+7358ms âPiston waited at a semaphore for 7262ms
+7360ms âRuntime (40426 bytes) successfully initialized in 7303ms (v0.3.10a.20190223) (7358ms)
+7361ms ââExecution stage started
+7382ms ââCondition #16 evaluated false (7ms)
+7384ms ââCondition group #15 evaluated false (state did not change) (9ms)
+7386ms ââExecution stage complete. (25ms)
+7389ms âSetting up scheduled job for Sat, Apr 20 2019 @ 9:00:00 AM BST (in 1s), with 2 more jobs pending
+7398ms âEvent processed successfully (7398ms)
Here is the ST event log for the device.
My thoughts are that this may have something to do with the last section starting and the large delay of 95672ms ?
Any help appreciated.
