(PUT YOUR INFO HERE) I created a piston that seems to match others I found here on the forum exactly (I hope) yet it isn’t running. The status changed to offline, yet I have not received any type of alert, email or SMS. Currently the device is OFFline, yet it is showing that is ONline.
(PUT YOUR INFO HERE) I expect the piston to run and check the status of the device, send an email and sms message if the device is offline.
(PUT YOUR INFO HERE) The piston is not checking the device.
(UPLOAD YOUR IMAGE HERE)
1/16/2020, 8:44:02 AM +66ms
+1ms ╔Received event [X].time = 1579182242506 with a delay of -440ms
+151ms ║RunTime Analysis CS > 33ms > PS > 57ms > PE > 60ms > CE
+153ms ║Runtime (39930 bytes) successfully initialized in 57ms (v0.3.110.20191009) (151ms)
+154ms ║╔Execution stage started
+177ms ║║Condition #6 evaluated false (11ms)
+178ms ║║Condition group #2 evaluated false (state did not change) (12ms)
+180ms ║║Cancelling statement #7’s schedules…
+186ms ║║Calculating (string) All devices are online as of + (string) Thu, Jan 16 2020 @ 8:44:02 AM EST >> (string) All devices are online as of Thu, Jan 16 2020 @ 8:44:02 AM EST
+188ms ║║Calculating (string) All devices are online as of Thu, Jan 16 2020 @ 8:44:02 AM EST + (string) ! >> (string) All devices are online as of Thu, Jan 16 2020 @ 8:44:02 AM EST!
+191ms ║║Executed virtual command setState (0ms)
+196ms ║╚Execution stage complete. (42ms)
+206ms ║Setting up scheduled job for Thu, Jan 16 2020 @ 9:14:02 AM EST (in 1800.234s)
+213ms ╚Event processed successfully (213ms)
