Received an Invalid Variable Error. I used this piston previously with smarthings, but stopped after I was not able to use Echo Speaks for the announcements. I am now using hubitat, I copied the ST piston over, but it is not making the announcement or texting my phone.
Receive notification after dryer stops running
I do not receive a notification
2/6/2021, 12:05:40 PM +749ms
+3ms ╔Received event [DCHome].time = 1612631140713 with a delay of 36ms, canQueue: true, calledMyself: false
+23ms ║RunTime initialize > 22 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 20 4 18)
+26ms ║Runtime (7606 bytes) successfully initialized in 1ms (v0.3.113.20210203_HE)
+31ms ║╔Execution stage started
+39ms ║║Cancelling condition #10’s schedules…
+40ms ║║Condition #10 evaluated true (2ms)
+44ms ║║Comparison (error) Variable ‘@DryerIsRunning’ not found is (boolean) true = false (1ms)
+46ms ║║Condition #11 evaluated false (5ms)
+48ms ║║Condition group #3 evaluated false (state did not change) (10ms)
+51ms ║╚Execution stage complete. (22ms)
+54ms ╚Event processed successfully (53ms)
2/6/2021, 12:05:10 PM +657ms
+3ms ╔Received event [Dryer].power = 3.3904 with a delay of 23ms, canQueue: true, calledMyself: false
+24ms ║RunTime initialize > 22 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 20 5 17)
+27ms ║Runtime (7579 bytes) successfully initialized in 1ms (v0.3.113.20210203_HE)
+28ms ║╔Execution stage started
+40ms ║║Comparison (decimal) 3.3904 stays_greater_than (integer) 50 = false (1ms)
+42ms ║║Cancelling any timed trigger schedules for condition 2
+43ms ║║Cancelling statement #2’s schedules…
+44ms ║║Cancelling condition #2’s schedules…
+45ms ║║Condition #2 evaluated false (9ms)
+47ms ║║Cancelling condition #1’s schedules…
+48ms ║║Condition group #1 evaluated false (state changed) (12ms)
+54ms ║║Comparison (decimal) 3.3904 stays_less_than (integer) 30 = true (1ms)
+56ms ║║Adding a timed trigger schedule for condition 10
+58ms ║║Condition #10 evaluated false (9ms)
+59ms ║║Condition group #3 evaluated false (state did not change) (10ms)
+67ms ║╚Execution stage complete. (39ms)
+83ms ║Setting up scheduled job for Sat, Feb 6 2021 @ 12:05:40 PM EST (in 30s)
+85ms ╚Event processed successfully (83ms)
2/6/2021, 12:04:39 PM +155ms
+5ms ╔Received event [DCHome].time = 1612631079085 with a delay of 70ms, canQueue: true, calledMyself: false
+22ms ║RunTime initialize > 21 LockT > 1ms > rtDT > 2ms > pistonT > 1ms (first state access 18 6 15)
+26ms ║Runtime (7598 bytes) successfully initialized in 2ms (v0.3.113.20210203_HE)
+29ms ║╔Execution stage started
+33ms ║║Cancelling condition #2’s schedules…
+34ms ║║Condition #2 evaluated true (2ms)
+35ms ║║Cancelling condition #1’s schedules…
+36ms ║║Condition group #1 evaluated true (state changed) (5ms)
+38ms ║║Cancelling statement #4’s schedules…
+44ms ║║Invalid variable @DryerIsRunning
+46ms ║║Executed virtual command setVariable (4ms)
+51ms ║╚Execution stage complete. (21ms)
+54ms ╚Event processed successfully (51ms)
2/6/2021, 12:04:09 PM +56ms
+3ms ╔Received event [Dryer].power = 251.1524 with a delay of 32ms, canQueue: true, calledMyself: false
+13ms ║RunTime initialize > 12 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 10 4 8)
+16ms ║Runtime (7537 bytes) successfully initialized in 1ms (v0.3.113.20210203_HE)
+18ms ║╔Execution stage started
+27ms ║║Comparison (decimal) 251.1524 stays_greater_than (integer) 50 = true (2ms)
+29ms ║║Adding a timed trigger schedule for condition 2
+32ms ║║Condition #2 evaluated false (11ms)
+34ms ║║Condition group #1 evaluated false (state did not change) (13ms)
+40ms ║║Comparison (decimal) 251.1524 stays_less_than (integer) 30 = false (1ms)
+41ms ║║Cancelling any timed trigger schedules for condition 10
+42ms ║║Cancelling statement #10’s schedules…
+43ms ║║Cancelling condition #10’s schedules…
+44ms ║║Condition #10 evaluated false (10ms)
+46ms ║║Condition group #3 evaluated false (state did not change) (11ms)
+50ms ║╚Execution stage complete. (32ms)
+65ms ║Setting up scheduled job for Sat, Feb 6 2021 @ 12:04:39 PM EST (in 30s)
+67ms ╚Event processed successfully (65ms)
