Piston to turn lights on with motion doesn’t always fire the first time even though piston woke up due to motion event. A few minutes later when motion is triggered again, lights come on. Sometimes it works on the first motion event, other times it does not.
Lights on during certain time (early morning when it’s still dark in the house) and motion (I come downstairs).
Sometimes works first time, sometimes second, always works eventually.
Logs are newest to oldest, go to bottom and read up!
It works this time with motion a few minutes later:
11/2/2018, 6:01:22 AM +787ms
+2ms ╔Received event [Living Room Motion].motion = active with a delay of 122ms
+243ms ║RunTime Analysis CS > 18ms > PS > 171ms > PE > 54ms > CE
+246ms ║Runtime (40901 bytes) successfully initialized in 171ms (v0.3.108.20180906) (242ms)
+247ms ║╔Execution stage started
+290ms ║║Comparison (datetime) 1541160083041 is_between (datetime) 1541138400000 … (datetime) 1541165400000 = true (4ms)
+293ms ║║Condition #7 evaluated true (39ms)
+298ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+300ms ║║Cancelling condition #6’s schedules…
+301ms ║║Condition #6 evaluated true (7ms)
+313ms ║║Comparison (enum) off is (string) off = true (1ms)
+315ms ║║Cancelling condition #18’s schedules…
+316ms ║║Condition #18 evaluated true (14ms)
+317ms ║║Cancelling condition #1’s schedules…
+318ms ║║Condition group #1 evaluated true (state changed) (65ms)
+322ms ║║Cancelling statement #2’s schedules…
+335ms ║║Executed physical command [Kitchen Pendants Dimmer].on() (10ms)
+336ms ║║Executed [Kitchen Pendants Dimmer].on (12ms)
+355ms ║║Executed physical command [Kitchen Pendants Dimmer].setLevel([100]) (9ms)
+356ms ║║Executed virtual command [Kitchen Pendants Dimmer].adjustLevel (16ms)
+359ms ║║Cancelling statement #22’s schedules…
+661ms ║║Executed physical command [VLC Thing].speak([Alexa, weather]) (294ms)
+662ms ║║Executed [VLC Thing].speak (296ms)
+669ms ║╚Execution stage complete. (422ms)
+671ms ║Setting up scheduled job for Fri, Nov 2 2018 @ 7:59:00 AM MDT (in 7056.543s)
+685ms ╚Event processed successfully (685ms)
Motion goes inactive again, normal:
11/2/2018, 6:01:13 AM +756ms
+1ms ╔Received event [Living Room Motion].motion = inactive with a delay of 113ms
+113ms ║RunTime Analysis CS > 17ms > PS > 36ms > PE > 61ms > CE
+116ms ║Runtime (40899 bytes) successfully initialized in 36ms (v0.3.108.20180906) (113ms)
+117ms ║╔Execution stage started
+156ms ║║Comparison (datetime) 1541160073880 is_between (datetime) 1541138400000 … (datetime) 1541165400000 = true (4ms)
+158ms ║║Condition #7 evaluated true (35ms)
+163ms ║║Comparison (enum) inactive changes_to (string) active = false (1ms)
+165ms ║║Condition #6 evaluated false (6ms)
+167ms ║║Condition group #1 evaluated false (state did not change) (43ms)
+172ms ║╚Execution stage complete. (55ms)
+174ms ║Setting up scheduled job for Fri, Nov 2 2018 @ 7:59:00 AM MDT (in 7066.071s)
+187ms ╚Event processed successfully (186ms)
Piston fires due to motion, but light doesn’t turn on first time:
11/2/2018, 5:56:42 AM +735ms
+2ms ╔Received event [Living Room Motion].motion = active with a delay of 218ms
+140ms ║RunTime Analysis CS > 25ms > PS > 57ms > PE > 57ms > CE
+142ms ║Runtime (40897 bytes) successfully initialized in 57ms (v0.3.108.20180906) (139ms)
+190ms ║║Comparison (datetime) 1541159802886 is_between (datetime) 1541138400000 … (datetime) 1541165400000 = true (5ms)
+192ms ║║Cancelling condition #7’s schedules…
+193ms ║║Condition #7 evaluated true (43ms)
+199ms ║║Comparison (enum) active changes_to (string) active = false (1ms)
+201ms ║║Cancelling condition #6’s schedules…
+202ms ║║Condition #6 evaluated false (8ms)
+203ms ║║Condition group #1 evaluated false (state did not change) (54ms)
+209ms ║╚Execution stage complete. (66ms)
+211ms ║Setting up scheduled job for Fri, Nov 2 2018 @ 7:59:00 AM MDT (in 7337.055s)
+227ms ╚Event processed successfully (227ms)
Last event night before:
11/1/2018, 9:25:58 PM +153ms
+1ms ╔Received event [Living Room Motion].motion = inactive with a delay of 63ms
+104ms ║RunTime Analysis CS > 16ms > PS > 34ms > PE > 53ms > CE
+106ms ║Runtime (40898 bytes) successfully initialized in 34ms (v0.3.108.20180906) (104ms)
+108ms ║╔Execution stage started
+148ms ║║Comparison (datetime) 1541129158268 is_between (datetime) 1541052000000 … (datetime) 1541078940000 = false (5ms)
+150ms ║║Condition #7 evaluated false (36ms)
+152ms ║║Condition group #1 evaluated false (state did not change) (38ms)
+157ms ║╚Execution stage complete. (50ms)
+159ms ║Setting up scheduled job for Fri, Nov 2 2018 @ 7:59:00 AM MDT (in 37981.689s)
+171ms ╚Event processed successfully (171ms)
