Piston stops before it finishes running. I think it’s because the trigger is not setup correctly.
Coffee maker turns on when bathroom light turns on, then coffee maker turns off 30 minutes later.
Coffee maker is not turning off 30 minutes later.
4)
1/30/2023, 5:53:41 AM +340ms
+4ms ╔Received event [Light-Master-Bath].switch/physical = off with a delay of 61ms, canQueue: true, calledMyself: false
+20ms ║Runtime (5920 bytes) initialized in 3ms (v0.3.114.20230103_HE)
+24ms ║╔Execution stage started
+53ms ║║Cancelling condition #2’s schedules…4 (st:6)
+59ms ║╚Execution stage complete. (35ms)
+82ms ╚Event processed successfully (78ms)
1/30/2023, 5:37:32 AM +266ms
+7ms ╔Received event [Light-Master-Bath].switch/physical = on with a delay of 53ms, canQueue: true, calledMyself: false
+38ms ║Runtime (5881 bytes) initialized in 3ms (v0.3.114.20230103_HE)
+40ms ║╔Execution stage started
+159ms ║║Executed device command [Coffee Maker].on() (51ms)
+170ms ║║Executed virtual command [Coffee Maker].wait [1800000] (1ms)
+175ms ║║Requesting wake up at Mon, Jan 30 2023 @ 6:07:32 AM CST (in 1799998ms) for 4 (st:6)
+182ms ║╚Execution stage complete. (142ms)
+217ms ║Setting up scheduled job for Mon, Jan 30 2023 @ 6:07:32 AM CST (in 1799979ms)
+221ms ╚Event processed successfully (215ms)
