Piston doesn’t fire. If I lock or unlock from ST app it will fire. But not when using the Lock itself.
trying to get the correct name of who opened
1/9/2021, 6:39:32 PM +750ms
+1ms ╔Received event [Side Door Lock].lock = locked with a delay of 51ms
+42ms ║RunTime Analysis CS > 16ms > PS > 6ms > PE > 20ms > CE
+45ms ║Runtime (44311 bytes) successfully initialized in 6ms (v0.3.110.20191009) (43ms)
+46ms ║╔Execution stage started
+51ms ║║Cancelling statement #23’s schedules…
+57ms ║║Executed virtual command [Side Door Lock, Front Door Lock].setVariable (3ms)
+61ms ║║Executed virtual command [Side Door Lock, Front Door Lock].setVariable (2ms)
+123ms ║║Calculating (decimal) 1.610235572819E12 - (decimal) 0.0 >> (decimal) 1.610235572819E12
+133ms ║║Calculating (string) + (string) Side Door Lock >> (string) Side Door Lock
+137ms ║║Calculating (string) Side Door Lock + (string) >> (string) Side Door Lock
+141ms ║║Calculating (string) Side Door Lock + (string) locked >> (string) Side Door Lock locked
+145ms ║║Calculating (string) Side Door Lock locked + (string) by >> (string) Side Door Lock locked by
+148ms ║║Calculating (string) Side Door Lock locked by + (string) I Don’t Know >> (string) Side Door Lock locked by I Don’t Know
+152ms ║║Calculating (string) Side Door Lock locked by I Don’t Know + (string) >> (string) Side Door Lock locked by I Don’t Know
+155ms ║║Calculating (string) Side Door Lock locked by I Don’t Know + (string) null >> (string) Side Door Lock locked by I Don’t Know null
+158ms ║║Calculating (string) Side Door Lock locked by I Don’t Know null + (string) on >> (string) Side Door Lock locked by I Don’t Know null on
+160ms ║║Calculating (string) Side Door Lock locked by I Don’t Know null on + (string) Sat, 09-Jan-2021 06:39:32 PM >> (string) Side Door Lock locked by I Don’t Know null on Sat, 09-Jan-2021 06:39:32 PM
+163ms ║║Calculating (string) Side Door Lock locked by I Don’t Know null on Sat, 09-Jan-2021 06:39:32 PM + (string) >> (string) Side Door Lock locked by I Don’t Know null on Sat, 09-Jan-2021 06:39:32 PM
+165ms ║║Executed virtual command [Side Door Lock, Front Door Lock].setState (1ms)
+178ms ║║Calculating (string) + (string) Side Door Lock >> (string) Side Door Lock
+182ms ║║Calculating (string) Side Door Lock + (string) >> (string) Side Door Lock
+186ms ║║Calculating (string) Side Door Lock + (string) locked >> (string) Side Door Lock locked
+190ms ║║Calculating (string) Side Door Lock locked + (string) by >> (string) Side Door Lock locked by
+193ms ║║Calculating (string) Side Door Lock locked by + (string) I Don’t Know >> (string) Side Door Lock locked by I Don’t Know
+197ms ║║Calculating (string) Side Door Lock locked by I Don’t Know + (string) >> (string) Side Door Lock locked by I Don’t Know
+200ms ║║Calculating (string) Side Door Lock locked by I Don’t Know + (string) null >> (string) Side Door Lock locked by I Don’t Know null
+203ms ║║Calculating (string) Side Door Lock locked by I Don’t Know null + (string) on >> (string) Side Door Lock locked by I Don’t Know null on
+206ms ║║Calculating (string) Side Door Lock locked by I Don’t Know null on + (string) Sat, Jan 9 2021 @ 6:39:32 PM EST >> (string) Side Door Lock locked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:32 PM EST
+208ms ║║Calculating (string) Side Door Lock locked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:32 PM EST + (string) Info 1 >> (string) Side Door Lock locked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:32 PM EST Info 1
+211ms ║║Side Door Lock locked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:32 PM EST Info 1
+212ms ║║Executed virtual command [Side Door Lock, Front Door Lock].log (1ms)
+223ms ║║Calculating (string) + (string) Status: >> (string) Status:
+228ms ║║Calculating (string) Status: + (string) locked >> (string) Status: locked
+231ms ║║Calculating (string) Status: locked + (string) User: >> (string) Status: locked User:
+235ms ║║Calculating (string) Status: locked User: + (string) I Don’t Know >> (string) Status: locked User: I Don’t Know
+238ms ║║Calculating (string) Status: locked User: I Don’t Know + (string) Method: >> (string) Status: locked User: I Don’t Know Method:
+241ms ║║Calculating (string) Status: locked User: I Don’t Know Method: + (string) null >> (string) Status: locked User: I Don’t Know Method: null
+244ms ║║Calculating (string) Status: locked User: I Don’t Know Method: null + (string) >> (string) Status: locked User: I Don’t Know Method: null
+246ms ║║Calculating (string) Status: locked User: I Don’t Know Method: null + (string) info 2 >> (string) Status: locked User: I Don’t Know Method: null info 2
+250ms ║║Status: locked User: I Don’t Know Method: null info 2
+251ms ║║Executed virtual command [Side Door Lock, Front Door Lock].log (1ms)
+260ms ║║Calculating (string) b,blue + (string) locked >> (string) b,bluelocked
+263ms ║║Calculating (string) User: >> (string) User:
+266ms ║║Calculating (string) User: + (string) User: [lockName:Side Door Lock]
+268ms ║║Calculating (string) User: User: [lockName:Side Door Lock]
+271ms ║║Calculating (string) User: User: [lockName:Side Door Lock] info 3
+274ms ║║ User: [lockName:Side Door Lock] info 3
+277ms ║║Executed virtual command [Side Door Lock, Front Door Lock].log (3ms)
+280ms ║║Evaluating switch with values [[i:52:null:0, v:[t:dynamic, v:null, vt:string]]]
+283ms ║║Comparison (dynamic) null is (integer) 1 = false (1ms)
+286ms ║║Comparison (dynamic) null is (integer) 2 = false (1ms)
+289ms ║║Comparison (dynamic) null is (integer) 3 = false (1ms)
+291ms ║║Comparison (dynamic) null is (integer) 4 = false (1ms)
+294ms ║║Comparison (dynamic) null is (integer) 5 = false (1ms)
+296ms ║║Cancelling statement #68’s schedules…
+301ms ║║Executed virtual command setVariable (2ms)
+304ms ║║Cancelling statement #70’s schedules…
+309ms ║║I Don’t Know
+310ms ║║Executed virtual command log (1ms)
+312ms ║╚Execution stage complete. (266ms)
+313ms ╚Event processed successfully (313ms)
1/9/2021, 6:39:21 PM +387ms
+1ms ╔Received event [Side Door Lock].lock = unlocked with a delay of 44ms
+42ms ║RunTime Analysis CS > 17ms > PS > 6ms > PE > 18ms > CE
+44ms ║Runtime (44309 bytes) successfully initialized in 6ms (v0.3.110.20191009) (42ms)
+45ms ║╔Execution stage started
+62ms ║║Executed virtual command [Side Door Lock, Front Door Lock].setVariable (3ms)
+126ms ║║Calculating (decimal) 1.610235561457E12 - (decimal) 0.0 >> (decimal) 1.610235561457E12
+135ms ║║Calculating (string) + (string) Side Door Lock >> (string) Side Door Lock
+140ms ║║Calculating (string) Side Door Lock + (string) >> (string) Side Door Lock
+144ms ║║Calculating (string) Side Door Lock + (string) unlocked >> (string) Side Door Lock unlocked
+148ms ║║Calculating (string) Side Door Lock unlocked + (string) by >> (string) Side Door Lock unlocked by
+152ms ║║Calculating (string) Side Door Lock unlocked by + (string) I Don’t Know >> (string) Side Door Lock unlocked by I Don’t Know
+155ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know + (string) >> (string) Side Door Lock unlocked by I Don’t Know
+158ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know + (string) null >> (string) Side Door Lock unlocked by I Don’t Know null
+161ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know null + (string) on >> (string) Side Door Lock unlocked by I Don’t Know null on
+164ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know null on + (string) Sat, 09-Jan-2021 06:39:21 PM >> (string) Side Door Lock unlocked by I Don’t Know null on Sat, 09-Jan-2021 06:39:21 PM
+167ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know null on Sat, 09-Jan-2021 06:39:21 PM + (string) >> (string) Side Door Lock unlocked by I Don’t Know null on Sat, 09-Jan-2021 06:39:21 PM
+169ms ║║Executed virtual command [Side Door Lock, Front Door Lock].setState (1ms)
+182ms ║║Calculating (string) + (string) Side Door Lock >> (string) Side Door Lock
+187ms ║║Calculating (string) Side Door Lock + (string) >> (string) Side Door Lock
+191ms ║║Calculating (string) Side Door Lock + (string) unlocked >> (string) Side Door Lock unlocked
+195ms ║║Calculating (string) Side Door Lock unlocked + (string) by >> (string) Side Door Lock unlocked by
+198ms ║║Calculating (string) Side Door Lock unlocked by + (string) I Don’t Know >> (string) Side Door Lock unlocked by I Don’t Know
+202ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know + (string) >> (string) Side Door Lock unlocked by I Don’t Know
+205ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know + (string) null >> (string) Side Door Lock unlocked by I Don’t Know null
+208ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know null + (string) on >> (string) Side Door Lock unlocked by I Don’t Know null on
+211ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know null on + (string) Sat, Jan 9 2021 @ 6:39:21 PM EST >> (string) Side Door Lock unlocked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:21 PM EST
+214ms ║║Calculating (string) Side Door Lock unlocked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:21 PM EST + (string) Info 1 >> (string) Side Door Lock unlocked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:21 PM EST Info 1
+217ms ║║Side Door Lock unlocked by I Don’t Know null on Sat, Jan 9 2021 @ 6:39:21 PM EST Info 1
+218ms ║║Executed virtual command [Side Door Lock, Front Door Lock].log (2ms)
+229ms ║║Calculating (string) + (string) Status: >> (string) Status:
+233ms ║║Calculating (string) Status: + (string) unlocked >> (string) Status: unlocked
+237ms ║║Calculating (string) Status: unlocked + (string) User: >> (string) Status: unlocked User:
+240ms ║║Calculating (string) Status: unlocked User: + (string) I Don’t Know >> (string) Status: unlocked User: I Don’t Know
+244ms ║║Calculating (string) Status: unlocked User: I Don’t Know + (string) Method: >> (string) Status: unlocked User: I Don’t Know Method:
+247ms ║║Calculating (string) Status: unlocked User: I Don’t Know Method: + (string) null >> (string) Status: unlocked User: I Don’t Know Method: null
+249ms ║║Calculating (string) Status: unlocked User: I Don’t Know Method: null + (string) >> (string) Status: unlocked User: I Don’t Know Method: null
+252ms ║║Calculating (string) Status: unlocked User: I Don’t Know Method: null + (string) info 2 >> (string) Status: unlocked User: I Don’t Know Method: null info 2
+255ms ║║Status: unlocked User: I Don’t Know Method: null info 2
+256ms ║║Executed virtual command [Side Door Lock, Front Door Lock].log (1ms)
+266ms ║║Calculating (string) b,blue + (string) unlocked >> (string) b,blueunlocked
+269ms ║║Calculating (string) User: >> (string) User:
+272ms ║║Calculating (string) User: + (string) User: [lockName:Side Door Lock]
+274ms ║║Calculating (string) User: User: [lockName:Side Door Lock]
+277ms ║║Calculating (string) User: User: [lockName:Side Door Lock] info 3
+280ms ║║ User: [lockName:Side Door Lock] info 3
+283ms ║║Executed virtual command [Side Door Lock, Front Door Lock].log (2ms)
+285ms ║║Evaluating switch with values [[i:52:null:0, v:[t:dynamic, v:null, vt:string]]]
+288ms ║║Comparison (dynamic) null is (integer) 1 = false (1ms)
+291ms ║║Comparison (dynamic) null is (integer) 2 = false (2ms)
+294ms ║║Comparison (dynamic) null is (integer) 3 = false (1ms)
+296ms ║║Comparison (dynamic) null is (integer) 4 = false (1ms)
+299ms ║║Comparison (dynamic) null is (integer) 5 = false (1ms)
+301ms ║║Cancelling statement #68’s schedules…
+307ms ║║Executed virtual command setVariable (3ms)
+310ms ║║Cancelling statement #70’s schedules…
+315ms ║║I Don’t Know
+316ms ║║Executed virtual command log (1ms)
+318ms ║╚Execution stage complete. (273ms)
+319ms ╚Event processed successfully (319ms)
