This piston should fire when a moisture detector’s status changes to wet. ST successfully sees a sensor has detected water but the piston never fires. I have edited and saved it multiple times but it doesn’t work. It did work previously.
The piston runs when a moisture detector detects water.
The piston never runs and the log is never populated.
