I have a piston that controls the heat. It doesn’t execute correctly when called by another piston but runs correct when executed by running “Test”. The reason I have this executed by another piston is I have it executed a different times based on time/temp/etc.
I’m expecting the downstairs temp to be set to 72.
It’s setting the temp to 68 most of the time
