Statements in piston execute though they should be blocked by restriction.
Statements should NOT execute.
See 1 & 2 above
5) Attach logs after turning logging level to Full – Sorry for the poor line spacing
Fourth run for scheduled trigger
Location mode is currently DAY
Turns lights off
6/19/2024, 5:40:06 AM +446ms
+6ms
╔Received event [Shoe’s].time = 1718793606388 with a delay of 58ms, canQueue: true, calledMyself: false
+24ms
║Runtime (16497 bytes) initialized 18 LockT > 1ms > r9T > 2ms > pistonT > 0ms (first state access 9 m:6 7 11) (v0.3.114.20240115_HE)
+32ms
║╔Execution stage started
+46ms
║║Condition #24 evaluated true (2ms)
+85ms
║║Comparison (enum) closed did_not_change = true (34ms)
+86ms
║║Condition #25 evaluated true (38ms)
+88ms
║║Condition group #23 evaluated true (condition changed) (43ms)
+90ms
║║Condition group #18 evaluated true (condition changed) (46ms)
+98ms
║║Command optimization: Skipped execution of device command [Cabinet Lights].off() because it would make no change to the device. (2ms)
+101ms
║║Command optimization: Skipped execution of device command [Fireplace Lights].off() because it would make no change to the device. (0ms)
+110ms
║║Calculating (string)Wed 6/19 5:40:06 + (string) - >> (string)Wed 6/19 5:40:06 -
+112ms
║║Calculating (string)Wed 6/19 5:40:06 - + (string)Bedroom Sensor >> (string)Wed 6/19 5:40:06 - Bedroom Sensor
+113ms
║║Calculating (string)Wed 6/19 5:40:06 - Bedroom Sensor + (string) triggered OFF
>> (string)Wed 6/19 5:40:06 - Bedroom Sensor triggered OFF
+118ms
║║Piston state changed
+119ms
║║Executed virtual command [Cabinet Lights, Fireplace Lights].setState (1ms)
+123ms
║║Calculating (string)Bedroom Sensor + (string) triggered OFF
>> (string)Bedroom Sensor triggered OFF
+126ms
║║Bedroom Sensor triggered OFF
+130ms
║║Executed virtual command [Cabinet Lights, Fireplace Lights].log (3ms)
+134ms
║╚Execution stage complete. (103ms)
+139ms
╚Event processed successfully (135ms)
Third run for scheduled triggers
Sets new timed trigger for Wed, Jun 19 2024 @ 5:40:06 AM CDT
6/19/2024, 5:36:06 AM +170ms
+6ms
╔Received event [Shoe’s].time = 1718793366145 with a delay of 25ms, canQueue: true, calledMyself: false
+22ms
║Runtime (16365 bytes) initialized 17 LockT > 1ms > r9T > 2ms > pistonT > 0ms (first state access 8 m:6 7 10) (v0.3.114.20240115_HE)
+30ms
+45ms
║║Condition #21 evaluated true (2ms)
+157ms
║║Found matching value, duration 161521ms for is < 240000ms threshold = true
+158ms
║║Comparison (enum) inactive was (string) inactive = true (109ms)
+192ms
║║Found matching value, duration 32738752ms for is < 240000ms threshold = false
+193ms
║║Comparison (enum) inactive was (string) inactive = false (35ms)
+194ms
║║Condition #22 evaluated false (149ms)
+195ms
║║Condition group #20 evaluated false (condition did not change) (153ms)
+205ms
║║Comparison (enum) inactive stays (string) inactive = true (1ms)
+207ms
+208ms
+210ms
+220ms
║║Adding a timed trigger schedule stays result true scheduling timer for condition 24 wake up at Wed, Jun 19 2024 @ 5:40:06 AM CDT (in 239998ms) for 24 (st:24)
+222ms
║║Condition #24 evaluated false (25ms)
+223ms
║║Condition group #23 evaluated false (condition did not change) (26ms)
+223ms
║║Condition group #18 evaluated false (condition did not change) (181ms)
+228ms
║╚Execution stage complete. (198ms)
+234ms
║Processing timer time = 1718793366149
+235ms
+247ms
║║Condition #21 evaluated true (0ms)
+289ms
║║Found matching value, duration 161658ms for is < 240000ms threshold = true
+290ms
║║Comparison (enum) inactive was (string) inactive = true (38ms)
+319ms
║║Found matching value, duration 32738879ms for is < 240000ms threshold = false
+320ms
║║Comparison (enum) inactive was (string) inactive = false (30ms)
+321ms
║║Condition #22 evaluated false (73ms)
+322ms
║║Condition group #20 evaluated false (condition did not change) (76ms)
+332ms
+333ms
+335ms
+337ms
║║Comparison (enum) inactive stays (string) inactive = true (0ms)
+343ms
║║Doing nothing found timed trigger schedule stays result true found timer for condition 24
+344ms
║║Condition #24 evaluated false (21ms)
+345ms
║║Condition group #23 evaluated false (condition did not change) (22ms)
+346ms
║║Condition group #18 evaluated false (condition did not change) (100ms)
+350ms
║╚Execution stage complete. (115ms)
+356ms
║Processing timer time = 1718793366152
+357ms
+368ms
║║Condition #21 evaluated true (1ms)
+410ms
║║Found matching value, duration 161780ms for is < 240000ms threshold = true
+411ms
+441ms
║║Found matching value, duration 32739000ms for is < 240000ms threshold = false
+442ms
+443ms
+444ms
+453ms
+455ms
+456ms
Second run when motion sensor goes inactive
3 timed triggers for Jun 19 2024 @ 5:36:06 AM CDT still in queue
6/19/2024, 5:33:24 AM +827ms
+4ms
╔Received event [Bedroom Sensor].motion = inactive with a delay of 30ms, canQueue: true, calledMyself: false
+21ms
║Runtime (16487 bytes) initialized 16 LockT > 0ms > r9T > 2ms > pistonT > 1ms (first state access 9 m:5 5 11) (v0.3.114.20240115_HE)
+23ms
+29ms
║║Comparison (enum) :32e164a2e42f34f83c6d5126248c9a8d: is (string) :db51cd17b1529242205547665623a183: = false (1ms)
+32ms
║║Condition #2 evaluated false (5ms)
+34ms
║║Condition group #1 evaluated false (condition changed) (7ms)
+38ms
║║Comparison (enum) :32e164a2e42f34f83c6d5126248c9a8d: is (string) :db51cd17b1529242205547665623a183: = false (0ms)
+40ms
║║Condition #19 evaluated false (6ms)
+41ms
║║Condition group #18 evaluated false (condition did not change) (7ms)
+46ms
║╚Execution stage complete. (23ms)
+140ms
║Setting up scheduled job for Wed, Jun 19 2024 @ 5:36:06 AM CDT (in 161243ms), with 2 more jobs pending
+142ms
╚Event processed successfully (138ms)
Hubitat log excerpt
App:1486 2024-06-19 05:31:06.548 AMinfo ║ Mode became Day from Night
App:946 2024-06-19 05:31:06.338 AMdebugReleased Lock and exiting
App:946 2024-06-19 05:31:06.177 AMwarn ║║ stays check stays isStays: true result: false options: [devices:[matched:[:e04d2faf96053e5556c56dd9a74dcde0:, :a50b8367be761b616503f003406c4554:, :bea7c04616599daf50d95a6459622cb3:], unmatched:[:c5302f51c1357b383e65b5c3b074dc1c:]], matches:true, forceAll:true]
App:946 2024-06-19 05:31:06.137 AMwarn ║║ stays check stays isStays: true result: true options: [devices:[matched:[:249f4ceacaed26fcec0f1c3da97f266d:, :635085f5f83511ac85d2722896cb5858:, :40dd9a4b70f5fd0d062af7de56919ea0:], unmatched:[]], matches:true, forceAll:true]
App:946 2024-06-19 05:31:06.085 AMinfo ║║ Bedroom Sensor triggered DAY mode 🟡
Dev:1496 2024-06-19 05:31:05.877 AMinfoBedroom Sensor motion became active
First run changes the location mode from NIGHT to DAY
Sets 3 timed triggers for Jun 19 2024 @ 5:36:06 AM CDT
6/19/2024, 5:31:05 AM +931ms
+7ms
╔Received event [Bedroom Sensor].motion = active with a delay of 51ms, canQueue: true, calledMyself: false
+24ms
║Runtime (16458 bytes) initialized 18 LockT > 1ms > r9T > 2ms > pistonT > 1ms (first state access 7 m:8 8 10) (v0.3.114.20240115_HE)
+25ms
+33ms
║║Comparison (enum) :db51cd17b1529242205547665623a183: is (string) :db51cd17b1529242205547665623a183: = true (1ms)
+36ms
║║Condition #2 evaluated true (7ms)
+38ms
║║Condition group #1 evaluated true (condition changed) (10ms)
+47ms
║║Comparison (enum) active changes_to (string) active = true (1ms)
+48ms
║║Condition #3 evaluated true (8ms)
+69ms
║║Comparison changes_to = false (event device/attr eXcluded)
+70ms
+71ms
+72ms
+73ms
║║Condition #4 evaluated false (24ms)
+74ms
║║Condition group #1 evaluated true (condition did not change) (34ms)
+95ms
║║Comparison (time) 19866000 is_between (time) 19800000 … (time) 23100000 = true (8ms)
+97ms
║║Time restriction check passed
+98ms
║║Condition #6 evaluated true (24ms)
+100ms
║║Condition group #5 evaluated true (condition did not change) (25ms)
+111ms
║║Executed virtual command cancelTasks (6ms)
+115ms
║║Executed virtual command setVariable (3ms)
+128ms
║║Calculating (string)Wed 6/19 5:31:05 + (string) - >> (string)Wed 6/19 5:31:05 -
+132ms
║║Calculating (string)Wed 6/19 5:31:05 - + (string)Bedroom Sensor >> (string)Wed 6/19 5:31:05 - Bedroom Sensor
+134ms
║║Calculating (string)Wed 6/19 5:31:05 - Bedroom Sensor + (string) triggered DAY mode 🟡 >> (string)Wed 6/19 5:31:05 - Bedroom Sensor triggered DAY mode 🟡
+137ms
+139ms
║║Executed virtual command setState (2ms)
+147ms
║║Calculating (string)Bedroom Sensor + (string) triggered DAY mode 🟡 >> (string)Bedroom Sensor triggered DAY mode 🟡
+152ms
║║Bedroom Sensor triggered DAY mode 🟡
+157ms
║║Executed virtual command log (6ms)
+174ms
║║Comparison (enum) :db51cd17b1529242205547665623a183: is (string) :db51cd17b1529242205547665623a183: = true (2ms)
+178ms
║║Condition #19 evaluated true (17ms)
+183ms
║║Condition group #18 evaluated true (condition changed) (21ms)
+199ms
║║Comparison (enum) closed stays (string) closed = true (2ms)
+202ms
║║Comparison (enum) closed stays (string) closed = true (1ms)
+205ms
+217ms
║║Adding a timed trigger schedule stays match in list scheduling timer for device :249f4ceacaed26fcec0f1c3da97f266d: for condition 21 wake up at Wed, Jun 19 2024 @ 5:36:06 AM CDT (in 299998ms) for 21 (st:21 / :249f4ceacaed26fcec0f1c3da97f266d:)
+220ms
║║Adding a timed trigger schedule stays match in list scheduling timer for device :635085f5f83511ac85d2722896cb5858: for condition 21 wake up at Wed, Jun 19 2024 @ 5:36:06 AM CDT (in 299999ms) for 21 (st:21 / :635085f5f83511ac85d2722896cb5858:)
+224ms
║║Adding a timed trigger schedule stays match in list scheduling timer for device :40dd9a4b70f5fd0d062af7de56919ea0: for condition 21 wake up at Wed, Jun 19 2024 @ 5:36:06 AM CDT (in 299999ms) for 21 (st:21 / :40dd9a4b70f5fd0d062af7de56919ea0:)
+226ms
║║Condition #21 evaluated false (40ms)
+228ms
║║Condition group #20 evaluated false (condition did not change) (43ms)
+238ms
║║Comparison (enum) active stays (string) inactive = false (1ms)
+240ms
+242ms
+244ms
+252ms
║║Cancel any timed trigger schedule stays result false cancel any timers for condition 24
+255ms
║║Condition #24 evaluated false (26ms)
+257ms
║║Condition group #23 evaluated false (condition changed) (29ms)
+260ms
║║Condition group #18 evaluated false (condition changed) (76ms)
+265ms
║╚Execution stage complete. (240ms)
+341ms
║Setting up scheduled job for Wed, Jun 19 2024 @ 5:36:06 AM CDT (in 299929ms), with 2 more jobs pending
