I have a bunch of pistons running in WebCore and every now and then my devices get replaced with a bunch of gibberish. I’m not sure why it’s happening and I end up having to go into the piston to reselect the devices to make the gibberish go away. When it’s happening my piston will stop working properly with half the lights turning on and half of them staying off even if they are listed in the piston. It’s happened quite a few times so I’m not sure what I’m doing wrong that causes this behaviour to happen. I couldn’t find anyone with a similar issue so would really appreciate it if anyone has any ideas on why this might be happening? Thanks.
The piston should turn on the lights when I enter the room and turn them off when no motion is detected for a while.
When the corruption happens only half the lights will work properly with the rest not responding to the automation.
