The piston isn’t “repeating” so I’m not getting a follow up email every one minute
When a door is open it will send an email to me every 1 minute
I get the initial email but not a follow up
10/15/2019, 9:24:37 AM +167ms
+1ms ╔Received event [Conga].time = 1571153078006 with a delay of -839ms
+93ms ║RunTime Analysis CS > 21ms > PS > 48ms > PE > 24ms > CE
+95ms ║Runtime (40950 bytes) successfully initialized in 48ms (v0.3.10f.20190822) (93ms)
+136ms ║║Comparison (enum) closed is (string) closed = true (1ms)
+139ms ║║Condition #14 evaluated true (34ms)
+140ms ║║Condition group #13 evaluated true (state did not change) (35ms)
+142ms ║╚Execution stage complete. (46ms)
+143ms ╚Event processed successfully (143ms)
10/15/2019, 9:23:37 AM +677ms
+1ms ╔Received event [Multipurpose Sensor].contact = open with a delay of 78ms
+60ms ║RunTime Analysis CS > 14ms > PS > 30ms > PE > 16ms > CE
+63ms ║Runtime (40929 bytes) successfully initialized in 30ms (v0.3.10f.20190822) (60ms)
+63ms ║╔Execution stage started
+101ms ║║Comparison (enum) closed is (string) open = false (1ms)
+103ms ║║Comparison (enum) closed is (string) open = false (1ms)
+105ms ║║Comparison (enum) closed is (string) open = false (1ms)
+107ms ║║Comparison (enum) closed is (string) open = false (1ms)
+109ms ║║Comparison (enum) open is (string) open = true (1ms)
+111ms ║║Comparison (enum) closed is (string) open = false (1ms)
+113ms ║║Comparison (enum) closed is (string) open = false (1ms)
+115ms ║║Comparison (enum) closed is (string) open = false (1ms)
+117ms ║║Comparison (enum) closed is (string) open = false (1ms)
+122ms ║║Cancelling condition #12's schedules...
+123ms ║║Condition #12 evaluated true (56ms)
+124ms ║║Cancelling condition #11's schedules...
+125ms ║║Condition group #11 evaluated true (state changed) (58ms)
+128ms ║║Cancelling statement #15's schedules...
+134ms ║║Calculating (string) The + (string) Multipurpose Sensor >> (string) The Multipurpose Sensor
+137ms ║║Calculating (string) The Multipurpose Sensor + (string) is open >> (string) The Multipurpose Sensor is open
+143ms ║║Calculating (string) The + (string) Multipurpose Sensor >> (string) The Multipurpose Sensor
+146ms ║║Calculating (string) The Multipurpose Sensor + (string) is open >> (string) The Multipurpose Sensor is open
+324ms ║║Executed virtual command sendEmail (176ms)
+327ms ║║Executed virtual command wait (0ms)
+328ms ║║Requesting a wake up for Tue, Oct 15 2019 @ 9:24:38 AM MDT (in 60.0s)
+332ms ║╚Execution stage complete. (269ms)
+334ms ║Setting up scheduled job for Tue, Oct 15 2019 @ 9:24:38 AM MDT (in 59.996s)
+362ms ╚Event processed successfully (362ms)
