Piston keeps cycling through all tasks instead of stopping and waiting to be triggered again.
I’m trying to make an NFC tag act as a Scene Switch.
I believe I have turned on the correct settings where the piston will only trigger when I scan an NFC tag (per https://community.webcore.co/t/running-piston-with-condition-only-once/1110/3)
When I scan an NFC tag this activates the piston.
When the piston is activated, it checks if any of 7 Hue lights are on.
If on, execute Scene A to turn off all the lights.
If off, execute Scenes B and C to turn on all the lights.
The tasks keep repeating, so it will continually cycle through turning all the lights off and on again.
Let me know if this would be helpful. The logs are neverending once the piston is triggered.
