I have a virtual switch in SmartThings.
I also have an IFTTT that will ARM my blink cameras when the switch is turned on.
I have a piston that turns that virtual switch on when there has been NO activity from the 2 motion sensors for at least one hour. The piston also locks the 2 exterior doors. None of that is working.
The virtual switch is not being turned on and no activity in the logs. I did test that if i turn on the switch that IFTTT is arming the blink system and that part is working.
Turning on the virtual button
The virtual switch is not turned on
1/2/2019, 4:07:34 PM +291ms
+1ms ╔Starting piston… (v0.3.109.20181207)
+137ms ║╔Subscribing to devices…
+171ms ║║Subscribing to Dome Motion/Light Sensor Kitchen.motion…
+184ms ║║Subscribing to Dome Motion/Light Sensor Front Door.motion…
+281ms ║║Subscribing to Virtual Blink Arm Switch…
+283ms ║║Subscribing to Front Door Lock…
+285ms ║║Subscribing to Kitchen Door To Garage Lock…
+286ms ║╚Finished subscribing (152ms)
+416ms ║Comparison (enum) inactive did_not_change = true (97ms)
+463ms ║Comparison (enum) inactive did_not_change = true (38ms)
+484ms ╚Piston successfully started (483ms)
1/2/2019, 4:07:28 PM +739ms
+103ms ╔Stopping piston…
+172ms ╚Piston successfully stopped (70ms)
1/2/2019, 12:53:52 PM +911ms
+207ms ║╔Subscribing to devices…
+243ms ║║Subscribing to Dome Motion/Light Sensor Kitchen.motion…
+261ms ║║Subscribing to Dome Motion/Light Sensor Front Door.motion…
+366ms ║║Subscribing to Virtual Blink Arm Switch…
+367ms ║║Subscribing to Front Door Lock…
+369ms ║║Subscribing to Kitchen Door To Garage Lock…
+370ms ║╚Finished subscribing (182ms)
+754ms ╚Piston successfully started (754ms)
