While developing a piston in one of the “then” sections I pasted some actions from another part of the piston, however the actions did not appear as expected. Now when I try to add a new actions the webCoRE interface won’t let me click the “Add a task” button. Is there a way to view the underlying code to remove whatever is bad in there?
Allow me to add the task, close dialogue box and display in the piston code.
On click the “Add a task” button does not react and the dialogue box remains open.
17/04/2018, 21:24:25 +824ms
+4ms ╔Starting piston… (v0.3.104.20180323)
+245ms ║╔Subscribing to devices…
+324ms ║║Subscribing to Hallway motion.motion…
+424ms ║╚Finished subscribing (190ms)
+476ms ║Comparison (enum) present is (string) present = true (4ms)
+484ms ║Comparison (string) off is_not (string) off = false (1ms)
+493ms ║Comparison (boolean) false is (boolean) false = true (1ms)
+516ms ║Comparison (enum) present is (string) present = true (0ms)
+518ms ║Comparison (enum) present is (string) present = true (2ms)
+524ms ║Comparison (string) off is (string) off = true (1ms)
+532ms ║Comparison (enum) inactive stays (string) inactive = true (2ms)
+535ms ║Comparison (boolean) false is (boolean) true = false (0ms)
+603ms ║Comparison (enum) closed did_not_change = true (60ms)
+613ms ║Comparison (enum) present is (string) not present = false (0ms)
+615ms ║Comparison (enum) present is (string) not present = false (1ms)
+621ms ║Comparison (string) off is (string) off = true (0ms)
+627ms ║Comparison (enum) inactive stays (string) inactive = true (1ms)
+630ms ║Comparison (boolean) false is (boolean) true = false (0ms)
+689ms ║Comparison (enum) closed changed = false (53ms)
+708ms ╚Piston successfully started (705ms)
17/04/2018, 21:23:19 +482ms
+1ms ╔Starting piston… (v0.3.104.20180323)
+150ms ║╔Subscribing to devices…
+168ms ║║Subscribing to Hallway motion.motion…
+234ms ║╚Finished subscribing (87ms)
+260ms ║Comparison (enum) present is (string) present = true (2ms)
+269ms ║Comparison (string) off is_not (string) off = false (1ms)
+277ms ║Comparison (boolean) false is (boolean) false = true (0ms)
+286ms ║Comparison (enum) present is (string) present = true (1ms)
+287ms ║Comparison (enum) present is (string) present = true (1ms)
+292ms ║Comparison (string) off is (string) off = true (1ms)
+298ms ║Comparison (enum) inactive stays (string) inactive = true (2ms)
+301ms ║Comparison (boolean) false is (boolean) true = false (1ms)
+402ms ║Comparison (enum) closed did_not_change = true (95ms)
+411ms ║Comparison (enum) present is (string) not present = false (0ms)
+412ms ║Comparison (enum) present is (string) not present = false (1ms)
+417ms ║Comparison (string) off is (string) off = true (0ms)
+423ms ║Comparison (enum) inactive stays (string) inactive = true (0ms)
+425ms ║Comparison (boolean) false is (boolean) true = false (0ms)
+451ms ║Comparison (enum) closed changed = false (21ms)
+458ms ╚Piston successfully started (458ms)
17/04/2018, 21:23:14 +329ms
+93ms ╔Stopping piston…
+163ms ╚Piston successfully stopped (72ms)
