Not sure if this is the right place for WebCore questions when running on Hubitat but will post here and see if I get an answer.
Have Zooz ZEN32 Scene Controller (“Basement Scene” or “Switch 10” in copy of piston) and using the big button which is button 5. I have a piston that tries to use pushed, held, and released events from that button of the scene controller as you can see in the copy of the piston below. Here is a copy of the events I set up for testing this piston:
You can see that I pressed button 5 (which turned on the switch for that device), then double-clicked it, then held it for about 3 seconds before releasing it. All of those events are captured by the log.
But the only time the piston triggers is for the double-tap. Am I doing something wrong or is there something about the ZEN32 device which doesn’t allow those attributes to be subscribed to. I should say that I have successfully used the switch state of the ZEN32 for some pistons but don’t have it in this piston.
Here is the piston log:
1/1/2024, 1:46:41 PM +680ms
+3ms ╔Received event [Basement Scene].doubleTapped = 5 with a delay of 29ms, canQueue: true, calledMyself: false
+70ms ║RunTime initialize > 69 LockT > 1ms > r9T > 55ms > pistonT > 53ms (first state access 9 m:13 5 64)
+74ms ║Runtime (13764 bytes) initialized in 55ms (v0.3.114.20231008_HE)
+76ms ║╔Execution stage started
+83ms ║║Comparison (integer) 5 gets (integer) 5 = true (0ms)
+85ms ║║Condition #2 evaluated true (6ms)
+87ms ║║Condition group #1 evaluated true (condition changed) (8ms)
+102ms ║║Comparison (enum) off is (enum) on = false (1ms)
+104ms ║║Condition #4 evaluated false (16ms)
+107ms ║║Condition group #3 evaluated false (condition changed) (18ms)
+139ms ║║Executed device command [Family Room Main].off() (25ms)
+139ms ║║Executed virtual command [Family Room Main].setSwitch (27ms)
+145ms ║║Comparison gets = false (event device/attr eXcluded)
+146ms ║║Condition #10 evaluated false (4ms)
+147ms ║║Condition group #9 evaluated false (condition did not change) (5ms)
+152ms ║║Comparison gets = false (event device/attr eXcluded)
+153ms ║║Condition #23 evaluated false (4ms)
+154ms ║║Condition group #22 evaluated false (condition did not change) (6ms)
+159ms ║║Comparison gets = false (event device/attr eXcluded)
+160ms ║║Condition #28 evaluated false (4ms)
+162ms ║║Condition group #27 evaluated false (condition did not change) (6ms)
+165ms ║╚Execution stage complete. (90ms)
+173ms ╚Event processed successfully (170ms)
1/1/2024, 1:45:50 PM +906ms
+4ms ╔Starting piston… (v0.3.114.20231008_HE)
+17ms ║╔Subscribing to devices…
+122ms ║║Device missing from piston. Loading all from parent (101ms)
+123ms ║║Attempting Attribute doubleTapped value [5] subscription for device: Basement Scene
+135ms ║║Attempting Attribute held value [5] subscription for device: Backdoor Scene
+152ms ║║Attempting Attribute released value [5] subscription for device: Backdoor Scene
+159ms ║║Attempting Attribute pushed value [5] subscription for device: Backdoor Scene
+162ms ║║Subscribing to Basement Scene.doubleTapped.5…
+178ms ║║SKIPPING sub: :5323ec41762ae70397679b1ffe350335:switch
+179ms ║║SKIPPING sub: :23d61524837a6b2934ec2783ee3e87f4:switch
+181ms ║║Subscribing to Backdoor Scene.held.5…
+188ms ║║Subscribing to Backdoor Scene.released.5…
+195ms ║║Subscribing to Backdoor Scene.pushed.5…
+204ms ║║Piston utilizes Family Room North [switch]…
+205ms ║║Piston utilizes Family Room Main [switch, level]…
+223ms ║╚Finished subscribing (215ms)
+232ms ║Subscribing to 12205-85th-Ave.pistonID…(:12b4f2c3efce23981fba8df3e29e4fc1:)
+240ms ║Subscribing to 12205-85th-Ave.oldpistonID…(:05779f22abad21b8ea747e9f03cc5c72:)
+252ms ║Comparison gets = false (event device/attr eXcluded)
+257ms ║Comparison (enum) on is (enum) on = true (1ms)
+264ms ║Comparison gets = false (event device/attr eXcluded)
+269ms ║Comparison (string) is (string) down = false (1ms)
+275ms ║Comparison gets = false (event device/attr eXcluded)
+281ms ║Comparison gets = false (event device/attr eXcluded)
+306ms ╚Piston started (302ms)
