Piston is not firing, and I suspect a problem with the events subscription or lack thereof. I would love an explanation of why it is not triggering.
I expect the piston to fire every Friday at specific times, that time being dependent on whether it is an odd or even week.
Logs show piston did not fire. During initial creation and testing things seemed OK, but no joy since then. Admittedly during testing I was focused on correct behavior of toggling the “cleaningWeek” variable. I suspect the events I have subscribed to (lines #32 and lines #38) are not causing the piston to trigger like I understand they should. So once again the event subscription subtleties are escaping me;-).
I did not paste a log since there were no useful ones since the piston did not fire (other than earlier testing mentioned which lacked any useful info).
(UPLOAD YOUR IMAGE HERE)
