Anyone having issues with WebCoRE, within the dashboard, properly showing the status of Smart Home Monitor, but not reflected with a piston that monitors it’s status? This is a new issue, never had a problem with this before…not sure if it has to do with the WebCoRE update today? I double checked and Smart Home Monitor is working perfectly…
I did some more testing and if the state of SHM changes (such as from armed to disarmed, etc.) then I see that message passed to the piston…no problem…so it looks like the way I had it set before doesn’t work anymore.
Here’s what I need:
A piston to monitor SHM status and if the status is in “unarmed” for a certain amount of time, I get notified…like I said, I had this working for many weeks no problem…not sure what happened…any suggestions?
Unfortunately, it looks like if there isn’t a change in the SHM, the piston doesn’t see this?
I also tested this with presence and I got the same results. For example, If XX stays present for XXX minutes, then XXX…that won’t work, because if the presence status doesn’t change, then the piston stays idle…
I know I am missing something basic here, but i don’t know what…
