Piston will not run when a device gets orphaned. It will run the first few devices and then stop once it reaches the orphaned device with an error. None of the actions get processed as a result.
It will continue to run on all devices and actually perform the actions on all devices (minus any orphaned device).
Piston errors out and never gets to the actions.
6/8/2022, 3:23:20 PM +30ms
+4ms ╔Received event [SmartThingsHub].test = 1654719800027 with a delay of 2ms
+114ms ║Runtime (40066 bytes) successfully initialized in 10ms (v0.3.114.20220203) (104ms)
+117ms ║╔Execution stage started
+6858ms ║║Executed [White Bulb 1].on (7ms)
+6866ms ║║Executed [Keypad 2].on (6ms)
+6873ms ║║Executed [White Bulb 2].on (6ms)
+6875ms ║║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
+6879ms ║╚Execution stage complete. (6762ms)
+6887ms ╚Event processed successfully (6887ms)
