I have a piston that i supposed to run when I close a door at night, however, it’s consistently failing to run on the first close, and requiring me to open then close the door again to activate it. What’d I miss?
Run the piston when the door is closed at night
Not always running
5) Attach any logs
1/15/2018, 9:28:20 PM +787ms
+1ms ╔Received event [Door - Tom’s Bedroom].contact = closed with a delay of 147ms
+94ms ║RunTime Analysis CS > 21ms > PS > 24ms > PE > 49ms > CE
+96ms ║Runtime (40417 bytes) successfully initialized in 24ms (v0.2.101.20171227) (94ms)
+159ms ║║Comparison (time) 77300891 is_between (time) 1516060800000 … (time) 1516026000000 = true (9ms)
+160ms ║║Time restriction check passed
+162ms ║║Condition #11 evaluated true (58ms)
+167ms ║║Comparison (enum) closed changes_to (string) closed = true (0ms)
+168ms ║║Cancelling condition #12’s schedules…
+169ms ║║Condition #12 evaluated true (6ms)
+170ms ║║Cancelling condition #1’s schedules…
+171ms ║║Condition group #1 evaluated true (state changed) (68ms)
+173ms ║║Cancelling statement #2’s schedules…
+186ms ║║Skipped execution of physical command [Aux garage lights].off([]) because it would make no change to the device. (3ms)
+187ms ║║Executed [Aux garage lights].off (4ms)
+192ms ║║Skipped execution of physical command [Backyard Lights].off([]) because it would make no change to the device. (2ms)
+193ms ║║Executed [Backyard Lights].off (4ms)
+199ms ║║Skipped execution of physical command [Camera Monitor].off([]) because it would make no change to the device. (2ms)
+199ms ║║Executed [Camera Monitor].off (4ms)
+204ms ║║Skipped execution of physical command [Cameras [Harmony Activity]].off([]) because it would make no change to the device. (2ms)
+205ms ║║Executed [Cameras [Harmony Activity]].off (4ms)
+211ms ║║Skipped execution of physical command [Closet Light].off([]) because it would make no change to the device. (3ms)
+212ms ║║Executed [Closet Light].off (4ms)
+233ms ║║Executed physical command [Counter Lights].off() (19ms)
+234ms ║║Executed [Counter Lights].off (20ms)
+240ms ║║Skipped execution of physical command [Dining Room Lights].off([]) because it would make no change to the device. (2ms)
+240ms ║║Executed [Dining Room Lights].off (4ms)
+396ms ║║Executed physical command [Doggie Light].off() (153ms)
+397ms ║║Executed [Doggie Light].off (155ms)
+403ms ║║Skipped execution of physical command [Entry Light].off([]) because it would make no change to the device. (3ms)
+404ms ║║Executed [Entry Light].off (4ms)
+409ms ║║Skipped execution of physical command [Family room lights].off([]) because it would make no change to the device. (3ms)
+410ms ║║Executed [Family room lights].off (4ms)
+415ms ║║Skipped execution of physical command [Fountain].off([]) because it would make no change to the device. (2ms)
+415ms ║║Executed [Fountain].off (3ms)
+421ms ║║Skipped execution of physical command [Foyer light].off([]) because it would make no change to the device. (3ms)
+422ms ║║Executed [Foyer light].off (4ms)
+448ms ║║Executed physical command [Hall lights].off() (24ms)
+449ms ║║Executed [Hall lights].off (25ms)
+454ms ║║Skipped execution of physical command [Kitchen Light].off([]) because it would make no change to the device. (2ms)
+455ms ║║Executed [Kitchen Light].off (4ms)
+460ms ║║Skipped execution of physical command [Living Room Lights].off([]) because it would make no change to the device. (2ms)
+461ms ║║Executed [Living Room Lights].off (4ms)
+467ms ║║Skipped execution of physical command [Living Room Touch Lights].off([]) because it would make no change to the device. (2ms)
+467ms ║║Executed [Living Room Touch Lights].off (4ms)
+473ms ║║Skipped execution of physical command [Main garage lights].off([]) because it would make no change to the device. (3ms)
+474ms ║║Executed [Main garage lights].off (4ms)
+479ms ║║Skipped execution of physical command [Nook Light].off([]) because it would make no change to the device. (3ms)
+480ms ║║Executed [Nook Light].off (3ms)
+484ms ║║Skipped execution of physical command [Office Heater].off([]) because it would make no change to the device. (2ms)
+485ms ║║Executed [Office Heater].off (4ms)
+491ms ║║Skipped execution of physical command [Office Task Lights].off([]) because it would make no change to the device. (3ms)
+492ms ║║Executed [Office Task Lights].off (4ms)
+497ms ║║Skipped execution of physical command [Shop Lights].off([]) because it would make no change to the device. (3ms)
+498ms ║║Executed [Shop Lights].off (4ms)
+503ms ║║Skipped execution of physical command [Store Room Lights].off([]) because it would make no change to the device. (3ms)
+504ms ║║Executed [Store Room Lights].off (4ms)
+509ms ║║Skipped execution of physical command [Watch apple TV (Family Room) [Harmony Activity]].off([]) because it would make no change to the device. (3ms)
+510ms ║║Executed [Watch apple TV (Family Room) [Harmony Activity]].off (3ms)
+515ms ║║Skipped execution of physical command [Watch TV (Family Room) [Harmony Activity]].off([]) because it would make no change to the device. (3ms)
+516ms ║║Executed [Watch TV (Family Room) [Harmony Activity]].off (4ms)
+519ms ║║Cancelling statement #4’s schedules…
+580ms ║║Executed physical command [Back porch light].setColor([[hex: #FFFF00, hue:17, saturation:100, level:50]]) (55ms)
+580ms ║║Executed [Back porch light].setColor (58ms)
+595ms ║║Skipped execution of physical command [Back porch light].setLevel([5]) because it would make no change to the device. (6ms)
+596ms ║║Executed virtual command [Back porch light].fadeLevel (10ms)
+599ms ║║Cancelling statement #9’s schedules…
+606ms ║║Skipped execution of physical command [Lock - Front Door].lock([]) because it would make no change to the device. (3ms)
+607ms ║║Executed [Lock - Front Door].lock (4ms)
+609ms ║║Cancelling statement #13’s schedules…
+667ms ║║Executed virtual command setLocationMode (55ms)
+680ms ║║Executed virtual command setAlarmSystemStatus (8ms)
+683ms ║╚Execution stage complete. (585ms)
+684ms ╚Event processed successfully (684ms)
1/15/2018, 9:28:07 PM +131ms
+1ms ╔Received event [Door - Tom’s Bedroom].contact = open with a delay of 547ms
+81ms ║RunTime Analysis CS > 13ms > PS > 23ms > PE > 45ms > CE
+84ms ║Runtime (40417 bytes) successfully initialized in 23ms (v0.2.101.20171227) (81ms)
+134ms ║║Comparison (time) 77287222 is_between (time) 1516060800000 … (time) 1516026000000 = true (9ms)
+135ms ║║Time restriction check passed
+137ms ║║Condition #11 evaluated true (47ms)
+141ms ║║Comparison (enum) open changes_to (string) closed = false (1ms)
+142ms ║║Condition #12 evaluated false (4ms)
+143ms ║║Condition group #1 evaluated false (state did not change) (53ms)
+145ms ║╚Execution stage complete. (61ms)
+147ms ╚Event processed successfully (146ms)
1/15/2018, 9:25:19 PM +995ms
+2ms ╔Received event [Door - Tom’s Bedroom].contact = closed with a delay of 665ms
+97ms ║RunTime Analysis CS > 23ms > PS > 27ms > PE > 46ms > CE
+99ms ║Runtime (40419 bytes) successfully initialized in 27ms (v0.2.101.20171227) (96ms)
+100ms ║╔Execution stage started
+162ms ║║Comparison (time) 77120101 is_between (time) 1516060800000 … (time) 1516026000000 = true (9ms)
+163ms ║║Time restriction check passed
+165ms ║║Cancelling condition #11’s schedules…
+166ms ║║Condition #11 evaluated true (60ms)
+170ms ║║Comparison (enum) closed changes_to (string) closed = false (0ms)
+172ms ║║Cancelling condition #12’s schedules…
+173ms ║║Condition #12 evaluated false (5ms)
+174ms ║║Condition group #1 evaluated false (state did not change) (67ms)
+176ms ║╚Execution stage complete. (76ms)
+177ms ╚Event processed successfully (177ms)`
