Hi, thanks for the reply. Not sure how to do that, what are the two log types?
I am switching color from red, to white, and it seems the red color stays on for some reason, although it seems to be executing the setRedLevel(0). When I cycle the colors in the other direction, I go from purple (red 100% + blue 100%) to white, and that works as intended.
The log under the piston code looks like this:
| +1ms |
╔Received event [LED strip Dimmer left button].button = pushed with a delay of 47ms |
| +81ms |
║RunTime Analysis CS > 14ms > PS > 4ms > PE > 62ms > CE |
| +84ms |
║Runtime (60560 bytes) successfully initialized in 4ms (v0.3.110.20191009) (82ms) |
| +85ms |
║╔Execution stage started |
| +97ms |
║║Condition #2 evaluated false (7ms) |
| +99ms |
║║Condition group #1 evaluated false (state did not change) (8ms) |
| +106ms |
║║Condition #33 evaluated false (6ms) |
| +107ms |
║║Condition group #32 evaluated false (state did not change) (8ms) |
| +112ms |
║║Comparison (enum) pushed gets (string) pushed = true (0ms) |
| +113ms |
║║Condition #66 evaluated true (5ms) |
| +114ms |
║║Condition group #64 evaluated true (state did not change) (6ms) |
| +120ms |
║║Comparison (integer) 0 is_equal_to (integer) 0 = true (1ms) |
| +122ms |
║║Cancelling condition #78’s schedules… |
| +123ms |
║║Condition #78 evaluated true (5ms) |
| +124ms |
║║Cancelling condition #73’s schedules… |
| +125ms |
║║Condition group #73 evaluated true (state changed) (8ms) |
| +127ms |
║║Cancelling statement #94’s schedules… |
| +394ms |
║║Executed physical command [LED strip].setRedLevel([0]) (263ms) |
| +395ms |
║║Executed [LED strip].setRedLevel (265ms) |
| +593ms |
║║Executed physical command [LED strip].setGreenLevel([0]) (194ms) |
| +593ms |
║║Executed [LED strip].setGreenLevel (195ms) |
| +799ms |
║║Executed physical command [LED strip].setBlueLevel([0]) (201ms) |
| +800ms |
║║Executed [LED strip].setBlueLevel (203ms) |
| +1033ms |
║║Executed physical command [LED strip].setWhiteLevel([100]) (229ms) |
| +1034ms |
║║Executed [LED strip].setWhiteLevel (231ms) |
| +1039ms |
║║Executed virtual command [LED strip].setVariable (3ms) |
| +1041ms |
║╚Execution stage complete. (956ms) |
| +1042ms |
╚Event processed successfully (1042ms) |
