I’m using a piston I found here on the community to notify if my garage or front door has been left open. After the duration period, I’m notified along with my room mates, how long the specific instance has been open, and then continually notified until the sensor is closed again. I’d like to do the same with the back door, but its a bit different. I’m so new at this its hard to wrap my head around it.
I’d like the back door to function like the others. We often leave the back door open for the dog most of the day, so the duration for notification is 8 hours open. After eight hours, I’d like to be notified, and then notified again once the door is closed.
Instead, after a certain amount of time leaving the door open we’ll be notified that the door has been closed. But, since 8 hours hasn’t gone by, this behavior is annoying. I’d only like to receive the notification if the door has already been open for the time specified.
12/17/2017, 2:59:59 PM +45ms +1ms ╔Received event [Back Door Sensor].contact = closed with a delay of 280ms +108ms ║RunTime Analysis CS > 17ms > PS > 26ms > PE > 64ms > CE +110ms ║Runtime (41695 bytes) successfully initialized in 26ms (v0.2.100.20171211) (108ms) +112ms ║╔Execution stage started +123ms ║║Comparison (enum) closed is (string) open = false (2ms) +124ms ║║Cancelling condition #6's schedules... +150ms ║║Calculating (long) 379843 / (long) 60000 >> (long) 6.3307166667 +154ms ║║Comparison (integer) 8 is_less_than (decimal) 6 = false (1ms) +155ms ║║Cancelling condition #10's schedules... +156ms ║║Condition #10 evaluated false (28ms) +157ms ║║Cancelling condition #7's schedules... +158ms ║║Condition group #7 evaluated false (state changed) (31ms) +160ms ║║Condition #6 evaluated false (41ms) +161ms ║║Cancelling condition #1's schedules... +161ms ║║Condition group #1 evaluated false (state changed) (44ms) +164ms ║╚Execution stage complete. (53ms) +166ms ╚Event processed successfully (166ms) 12/17/2017, 2:53:39 PM +634ms +2ms ╔Received event [Back Door Sensor].contact = open with a delay of 286ms +129ms ║RunTime Analysis CS > 30ms > PS > 34ms > PE > 64ms > CE +131ms ║Runtime (41697 bytes) successfully initialized in 34ms (v0.2.100.20171211) (129ms) +132ms ║╔Execution stage started +144ms ║║Comparison (enum) open is (string) open = true (2ms) +146ms ║║Cancelling condition #6's schedules... +146ms ║║Condition #6 evaluated true (7ms) +148ms ║║Cancelling condition #1's schedules... +148ms ║║Condition group #1 evaluated true (state changed) (10ms) +151ms ║║Cancelling statement #2's schedules... +154ms ║║Executed virtual command wait (0ms) +156ms ║║Requesting a wake up for Sun, Dec 17 2017 @ 10:53:39 PM PST (in 28800.0s) +161ms ║╚Execution stage complete. (29ms) +163ms ║Setting up scheduled job for Sun, Dec 17 2017 @ 10:53:39 PM PST (in 28799.994s) +174ms ╚Event processed successfully (173ms) 12/17/2017, 1:16:50 PM +996ms +1ms ╔Received event [Back Door Sensor].contact = closed with a delay of 461ms +95ms ║RunTime Analysis CS > 16ms > PS > 24ms > PE > 56ms > CE +98ms ║Runtime (41694 bytes) successfully initialized in 24ms (v0.2.100.20171211) (96ms) +99ms ║╔Execution stage started +110ms ║║Comparison (enum) closed is (string) open = false (2ms) +112ms ║║Cancelling condition #6's schedules... +133ms ║║Calculating (long) 8634080 / (long) 60000 >> (long) 143.9013333333 +137ms ║║Comparison (integer) 8 is_less_than (decimal) 143 = true (1ms) +138ms ║║Cancelling condition #10's schedules... +139ms ║║Condition #10 evaluated true (25ms) +140ms ║║Cancelling condition #7's schedules... +141ms ║║Condition group #7 evaluated true (state changed) (27ms) +143ms ║║Cancelling statement #8's schedules... +268ms ║║Executed virtual command sendPushNotification (120ms) +286ms ║║Executed virtual command sendSMSNotification (10ms) +305ms ║║Executed virtual command sendSMSNotification (11ms) +307ms ║║Condition #6 evaluated false (202ms) +308ms ║║Cancelling condition #1's schedules... +309ms ║║Condition group #1 evaluated false (state changed) (204ms) +312ms ║╚Execution stage complete. (213ms) +313ms ╚Event processed successfully (313ms) 12/17/2017, 10:52:57 AM +552ms +1ms ╔Received event [Back Door Sensor].contact = open with a delay of 506ms +100ms ║RunTime Analysis CS > 23ms > PS > 24ms > PE > 54ms > CE +103ms ║Runtime (41697 bytes) successfully initialized in 24ms (v0.2.100.20171211) (101ms) +104ms ║╔Execution stage started +115ms ║║Comparison (enum) open is (string) open = true (1ms) +116ms ║║Cancelling condition #6's schedules... +117ms ║║Condition #6 evaluated true (7ms) +118ms ║║Cancelling condition #1's schedules... +119ms ║║Condition group #1 evaluated true (state changed) (10ms) +122ms ║║Cancelling statement #2's schedules... +125ms ║║Executed virtual command wait (1ms) +126ms ║║Requesting a wake up for Sun, Dec 17 2017 @ 6:52:57 PM PST (in 28800.0s) +131ms ║╚Execution stage complete. (28ms) +133ms ║Setting up scheduled job for Sun, Dec 17 2017 @ 6:52:57 PM PST (in 28799.995s) +143ms ╚Event processed successfully (143ms)
