I want a couple lights to turn off late at night if the motion sensor doesn’t pick up motion between midnight and 5:30am. I know the piston works properly because when I test the piston, it behaves as I want it to. The problem is that the piston never appears to run on its own, only after I test it.
When the motion sensor doesn’t detect any motion during specific hours, lights turn off.
The piston never appears to run on its own, it only runs when I test it
