My piston used to work fine before, but recently I have noticed that it works randomly.
When a presence Sensor changes to present 30mins before sunset, some lights should go on.
This piston used to work fine till a few months back, and now it works only once in a while, even though its way past sunset.
WORKING Piston:
26/09/2018, 22:56:15 +97ms
+2ms ╔Received event [BMW].presence = present with a delay of 185ms
+121ms ║RunTime Analysis CS > 20ms > PS > 61ms > PE > 40ms > CE
+124ms ║Runtime (38290 bytes) successfully initialized in 61ms (v0.3.108.20180906) (121ms)
+172ms ║║Comparison (time) 82575228 is_between (time) 1537984260000 … (time) 1537941180000 = true (14ms)
+173ms ║║Time restriction check passed
+175ms ║║Condition #9 evaluated true (45ms)
+189ms ║║Comparison (enum) present changes_to (string) present = true (1ms)
+192ms ║║Cancelling condition #10’s schedules…
+193ms ║║Condition #10 evaluated true (17ms)
+194ms ║║Cancelling condition #1’s schedules…
+195ms ║║Condition group #1 evaluated true (state changed) (65ms)
+198ms ║║Cancelling statement #2’s schedules…
+219ms ║║Executed physical command [Garage Light].on() (15ms)
+220ms ║║Executed [Garage Light].on (17ms)
+259ms ║║Executed physical command [Patio Light].on() (36ms)
+260ms ║║Executed [Patio Light].on (38ms)
+283ms ║║Executed physical command [Porch Light].on() (20ms)
+285ms ║║Executed [Porch Light].on (22ms)
+309ms ║║Executed physical command [Shed Light].on() (21ms)
+310ms ║║Executed [Shed Light].on (23ms)
+314ms ║║Executed virtual command [Garage Light, Patio Light, Porch Light, Shed Light].wait (1ms)
+316ms ║║Requesting a wake up for Wed, Sep 26 2018 @ 11:03:15 PM BST (in 420.0s)
+321ms ║╚Execution stage complete. (197ms)
+323ms ║Setting up scheduled job for Wed, Sep 26 2018 @ 11:03:15 PM BST (in 419.995s)
+331ms ╚Event processed successfully (331ms)
FAILED Piston:
28/09/2018, 19:59:46 +415ms
+1ms ╔Received event [Vierka].presence = present with a delay of 75ms
+118ms ║RunTime Analysis CS > 16ms > PS > 47ms > PE > 55ms > CE
+120ms ║Runtime (38288 bytes) successfully initialized in 47ms (v0.3.108.20180906) (119ms)
+122ms ║╔Execution stage started
+171ms ║║Comparison (time) 71986544 is_between (time) 1538156760000 … (time) 1538114160000 = true (14ms)
+175ms ║║Cancelling condition #9’s schedules…
+176ms ║║Condition #9 evaluated true (48ms)
+191ms ║║Comparison (enum) present changes_to (string) present = false (1ms)
+193ms ║║Cancelling condition #10’s schedules…
+195ms ║║Condition #10 evaluated false (17ms)
+196ms ║║Condition group #1 evaluated false (state did not change) (68ms)
+199ms ║╚Execution stage complete. (77ms)
+200ms ╚Event processed successfully (201ms)
