I’m using motion based occupancy to control the two thermostats in my house. It works well during our typical daily routine, however there are times when I would like to override the piston or portions of the piston based on manual user input. I’m trying to understand how I can set up webcore to “see” when a user has manually changed a temp setting on the thermostat.
I would like the piston to either pause or take different action when ST detects that a device (thermostat temp in this case) has been manually changed.
Currently, the piston continues to monitor motion and change thermostat settings based on the piston settings, even after the thermostat temperature has been manually changed. I need to be able to detect a device variable (?) that tells webcore that the thermostat has received user input and now needs to do something different.
Any suggestions?
