I’m not sure who to restrict my piston so that it only executes between Black Friday and New Year’s Day. I’m sure this is going to have to be some kind of expression but I don’t have the first clue how to start it.
I know it’ll always be the fourth Friday of November but I’m not sure how to write it. I also want it to end so that the piston doesn’t execute past 1/1/20xx. I’d like it to be agnostic of the current year. I assume this is easy enough with $year.
Also, is my piston configured efficiently to mirror two switches? It works just fine for both on and off no matter which switch is changed. A smarter set of eyes is always helpful. I was also considering putting both switches in a variable and if one switch changed, the one that didn’t would take the first one’s action (on/off). I wasn’t sure how to write it so I just went with (if switch(if true{change}) elseif switch (if true{change}))
Restrict piston to only execute between Black Friday and New Year’s day. The piston will mirror two switches. These two outlets have Christmas lights attached during the time i want this restriction enforced. Outside of these dates, the outlets have different things attached and I don’t want them mirrored.
The action in the piston executes as desired. I need help designing the restriction.
‘No logs required at this time’
