Piston Save Stops at 17 of 18 Chunks
What does it mean when attempting to save a piston, that it goes to 17 of 18 chunks, then stops and does not save? Have I run out of Webcore memory? Do I fix it by creating another instance of Webcore (I already have 2, one for pistons for automation and one for only tiles. This occurs in the Tiles instance.)?
I don’t know what the maximum size is, but I’ve heard of people exceeding it.
Is there a way to tell how much memory has been consumed, and how much remains? And how much the piston that I’m trying to save will consume?
This can either be a memory issue or there might be an error in an expression throwing an exception.
First try going into the webCoRE app within the ST mobile app > settings > clean up and rebuild data cache.
Failing that, log out of the web browser session and back in again.
Thanks, I tried the Cleanup, and while it now got thru all 18 chunks, it would not save. So now I’m trying logging out and back in, but having trouble doing that. Still working on it.
I’ve been unsuccessful at re-logging into that instance of Webcore. I keep getting the message “There was a problem loading the databoard data …”. I have tried it from different browsers, and from Incognito modes of multiple browsers but no joy. What can I do?
Well, as soon as I pressed Send, I tried it again, and this time it worked. I’m good for now.
