Hello,
I have a piston that watches the temperature in a greenhouse. It’s a pretty simple piston. When temperature equal to or greater than 70° turn on fan. That works just fine. It also triggers an SMS notification telling me the fan is on and that the temperature has reached 70° or greater. that works fine except it continues to send that message with every change in temperature. I really only want one notice. Any thoughts? I deleted the piston and will wait for suggestions
Piston sending multiple SMS messages
jkb121zed
WCmore
I am thinking something like this:
IF Device's temperature RISES ABOVE 69° (a trigger instead of a condition)
Turn on Fan
Send SMS
END IF
This one will only alert you once, at the moment the temp rises above 69°.
WCmore
Just be aware that if the current temp is already above 69°, the fan will not come on this new piston until the temp drops, and then rises again. (this only happens on a newly created/edited piston, and will normally run as expected)
