(PUT YOUR INFO HERE)
This piston worked great on smartthings. It stopped working when I migrated to Hubitat C-8 Webcore v0.3.114
I have if else statements checking the value of a global variable. They show up as triggers with the lightning symbol. Every time the variable changes, the routine is triggered.
@CurrentRoom is Kitchen
I resolved the problem by assigning the global variable to a local variable then using the local variable in the conditions.
Set variable {Room} = {@@CurrentRoom}
Should behave like with local variable, not triggering on variable change.
Piston is being triggered on variable change when it is supposed to be a condition.
4/4/2023, 12:25:19 PM +863ms
+2ms ╔Received event [RosieH(new)].variable:GuestComplete = true with a delay of 24ms, canQueue: true, calledMyself: false
+21ms ║Runtime (23127 bytes) initialized in 1ms (v0.3.114.20230222_HE)
+22ms ║╔Execution stage started
+28ms ║║RamjetRooms. Called by: Variable ‘GuestComplete’ set to true CEO: variable:GuestComplete
(UPLOAD YOUR IMAGE HERE)
4/4/2023, 12:26:57 PM +760ms
+2ms ╔Received event [RosieH(new)].execute = :06ea22376b6e27547a0ebd61b37d628c: with a delay of 17ms, canQueue: true, calledMyself: false
+15ms ║Runtime (23147 bytes) initialized in 1ms (v0.3.114.20230222_HE)
+16ms ║╔Execution stage started
+23ms ║║RamjetRooms. Called by: CEO: execute
+25ms ║║Executed virtual command log (2ms)
+70ms ║║Executed virtual command sendPushNotification (20ms)
+106ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+108ms ║║Executed virtual command log (2ms)
+114ms ║║Executed virtual command setVariable (4ms)
+150ms ║║Executed virtual command sendPushNotification (11ms)
+186ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+188ms ║║Executed virtual command log (2ms)
+194ms ║║Executed virtual command setVariable (5ms)
+233ms ║║Executed virtual command sendPushNotification (14ms)
+381ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+383ms ║║Executed virtual command log (2ms)
+389ms ║║Executed virtual command setVariable (5ms)
+391ms ║╚Execution stage complete. (375ms)
+393ms ╚Event processed successfully (390ms)
4/4/2023, 12:25:20 PM +195ms
+1ms ╔Received event [RosieH(new)].execute = :06ea22376b6e27547a0ebd61b37d628c: with a delay of 240ms, canQueue: false, calledMyself: true
+9ms ║Runtime (23103 bytes) initialized in 1ms (v0.3.114.20230222_HE)
+9ms ║╔Execution stage started
+15ms ║║RamjetRooms. Called by: CEO: execute
+17ms ║║Executed virtual command log (2ms)
+61ms ║║Executed virtual command sendPushNotification (19ms)
+98ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+100ms ║║Executed virtual command log (2ms)
+106ms ║║Executed virtual command setVariable (4ms)
+142ms ║║Executed virtual command sendPushNotification (11ms)
+178ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+180ms ║║Executed virtual command log (2ms)
+185ms ║║Executed virtual command setVariable (4ms)
+222ms ║║Executed virtual command sendPushNotification (10ms)
+257ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+259ms ║║Executed virtual command log (2ms)
+265ms ║║Executed virtual command setVariable (5ms)
+267ms ║╚Execution stage complete. (258ms)
+268ms ╚Event processed successfully (268ms)
+30ms ║║Executed virtual command log (2ms)
+91ms ║║Executed virtual command sendPushNotification (21ms)
+142ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+145ms ║║Executed virtual command log (2ms)
+151ms ║║Executed virtual command setVariable (4ms)
+188ms ║║Executed virtual command sendPushNotification (11ms)
+223ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+225ms ║║Executed virtual command log (2ms)
+231ms ║║Executed virtual command setVariable (5ms)
+268ms ║║Executed virtual command sendPushNotification (11ms)
+304ms ║║Completed all rooms: K: true B: true L: true G: true RJcomplete: trueRJinterr: false
+306ms ║║Executed virtual command log (2ms)
+312ms ║║Executed virtual command setVariable (4ms)
+313ms ║╚Execution stage complete. (292ms)
+314ms ╚Event processed successfully (313ms)
4/4/2023, 12:25:20 PM +1ms
+3ms ╔Received event [RosieH(new)].execute = :06ea22376b6e27547a0ebd61b37d628c: with a delay of 46ms, canQueue: true, calledMyself: false
+3ms ╚Event queued (1ms)
4/4/2023, 12:23:27 PM +136ms
+3ms ╔Received event [RosieH(new)].wc_async_reply = iftttMaker with a delay of 0ms, canQueue: true, calledMyself: false
+17ms ║Runtime (23132 bytes) initialized in 1ms (v0.3.114.20230222_HE)
+35ms ║╔Execution stage started
+52ms ║║Executed virtual command setVariable (6ms)
+53ms ║╚Execution stage complete. (19ms)
+55ms ╚Event processed successfully (51ms)
4/4/2023, 12:23:26 PM +847ms
+2ms ╔Received event [RosieH(new)].wc_async_reply = iftttMaker with a delay of 0ms, canQueue: true, calledMyself: false
+16ms ║Runtime (23127 bytes) initialized in 1ms (v0.3.114.20230222_HE)
+88ms ║║Executed virtual command iftttMaker (2ms)
+90ms ║║Requesting wake up at Tue, Apr 4 2023 @ 12:23:50 PM PDT (in 23999ms) for 86 (st:87)
+93ms ║╚Execution stage complete. (58ms)
+131ms ║Setting up scheduled job for Tue, Apr 4 2023 @ 12:23:50 PM PDT (in 23991ms)
+132ms ╚Event processed successfully (130ms)
4/4/2023, 12:23:26 PM +479ms
+2ms ╔Received event [RosieH(new)].wc_async_reply = iftttMaker with a delay of 1ms, canQueue: true, calledMyself: false
+16ms ║Runtime (23116 bytes) initialized in 1ms (v0.3.114.20230222_HE)
+41ms ║╔Execution stage started
+59ms ║║Executed virtual command setVariable (12ms)
+91ms ║║Starting Ramjet in Guest K: true B: true L: true G: false
+93ms ║║Executed virtual command log (2ms)
+143ms ║║Executed virtual command sendPushNotification (22ms)
+175ms ║║Executed virtual command iftttMaker (3ms)
+177ms ║║Requesting wake up at Tue, Apr 4 2023 @ 12:23:50 PM PDT (in 23999ms) for 57 (st:58)
+179ms ║╚Execution stage complete. (138ms)
+207ms ║Setting up scheduled job for Tue, Apr 4 2023 @ 12:23:50 PM PDT (in 23994ms)
+208ms ╚Event processed successfully (207ms)
4/4/2023, 12:23:25 PM +745ms
+3ms ╔Received event [RosieH(new)].execute = :06ea22376b6e27547a0ebd61b37d628c: with a delay of 19ms, canQueue: true, calledMyself: false
+278ms ║Runtime (23188 bytes) initialized in 264ms (v0.3.114.20230222_HE)
+279ms ║╔Execution stage started
+286ms ║║RamjetRooms. Called by: CEO: execute
+287ms ║║Executed virtual command log (2ms)
+316ms ║║Executed virtual command iftttMaker (1ms)
+317ms ║║Requesting wake up at Tue, Apr 4 2023 @ 12:23:50 PM PDT (in 23999ms) for 25 (st:26)
+319ms ║╚Execution stage complete. (40ms)
+356ms ║Setting up scheduled job for Tue, Apr 4 2023 @ 12:23:50 PM PDT (in 23994ms)
+357ms ╚Event processed successfully (354ms)
4/4/2023, 11:55:23 AM +353ms
+2ms ╔Starting piston… (v0.3.114.20230222_HE)
+90ms ║╔Subscribing to devices…
+273ms ║║Subscribing to RosieH(new).variable:GuestComplete…
+288ms ║╚Finished subscribing (284ms)
+387ms ╚Piston started (385ms)
