I have two switchbots to control my A/C since the thermostat has no smart capabilities. I have set up one switch to turn it on and the other to change between only fan and cool air. The problem is, at least from what I gather, is that in the execution of the piston it is skipping one of the toggles which throws everything off.
When A/C turns on I want the switchbot to toggle four times (this would set the A/C mode to fan only) then I want it to wait and hour and toggle the switch again (this would set the A/C to cool air), wait 30 minutes, and repeat the process until the A/C is turned off…at that point the piston should stop until the A/C is turned on again.
From my little understanding of the logs, it seems like the execution starts well but then for some reason, it sees the switchbot as off and skips a step as it wouldn’t change anything.
8/7/2021, 12:22:53 PM +835ms
+62ms ╔Stopping piston…
+162ms ╚Piston successfully stopped (100ms)
8/7/2021, 12:18:43 PM +521ms
+2ms ╔Received event [Air conditioner].switch = off with a delay of 62ms
+6812ms ║RunTime Analysis CS > 17ms > PS > 6763ms > PE > 32ms > CE
+6813ms ║Piston waited at a semaphore for 6759ms
+6816ms ║Runtime (38039 bytes) successfully initialized in 6763ms (v0.3.113.20210203) (6813ms)
+6816ms ║╔Execution stage started
+6823ms ║║Comparison (enum) off changes_to (string) on = false (0ms)
+6825ms ║║Cancelling condition #2’s schedules…
+6826ms ║║Condition #2 evaluated false (6ms)
+6827ms ║║Cancelling condition #1’s schedules…
+6828ms ║║Condition group #1 evaluated false (state changed) (8ms)
+6830ms ║╚Execution stage complete. (14ms)
+6836ms ╚Event processed successfully (6836ms)
8/7/2021, 12:18:40 PM +118ms
+0ms ╔Received event [Home].time = 1628331521163 with a delay of -1046ms
+81ms ║RunTime Analysis CS > 43ms > PS > 5ms > PE > 34ms > CE
+84ms ║Runtime (37962 bytes) successfully initialized in 5ms (v0.3.113.20210203) (82ms)
+108ms ║║Condition #5 evaluated false (10ms)
+109ms ║║Condition group #4 evaluated false (state did not change) (12ms)
+112ms ║║Cancelling statement #6’s schedules…
+136ms ║║Executed physical command [AC FAN].on() (18ms)
+137ms ║║Executed [AC FAN].on (21ms)
+143ms ║║Executed virtual command [AC FAN].wait (0ms)
+144ms ║║Waiting for 2000ms
+2180ms ║║Executed physical command [AC FAN].off() (18ms)
+2181ms ║║Executed virtual command [AC FAN].toggle (34ms)
+2187ms ║║Executed virtual command [AC FAN].wait (1ms)
+2188ms ║║Waiting for 2000ms
+4225ms ║║Executed physical command [AC FAN].on() (17ms)
+4226ms ║║Executed virtual command [AC FAN].toggle (35ms)
+4232ms ║║Executed virtual command [AC FAN].wait (1ms)
+4233ms ║║Waiting for 2000ms
+6264ms ║║Executed physical command [AC FAN].off() (16ms)
+6266ms ║║Executed virtual command [AC FAN].toggle (28ms)
+6272ms ║║Executed virtual command [AC FAN].wait (1ms)
+6274ms ║║Requesting a wake up for Sat, Aug 7 2021 @ 12:18:56 PM CEST (in 10.0s)
+6279ms ║╚Execution stage complete. (6195ms)
+6281ms ║Setting up scheduled job for Sat, Aug 7 2021 @ 12:18:56 PM CEST (in 9s)
+6289ms ╚Event processed successfully (6289ms)
8/7/2021, 12:18:11 PM +58ms
+0ms ╔Received event [Home].time = 1628331492451 with a delay of -1394ms
+64ms ║RunTime Analysis CS > 25ms > PS > 6ms > PE > 34ms > CE
+66ms ║Runtime (37962 bytes) successfully initialized in 6ms (v0.3.113.20210203) (65ms)
+90ms ║║Skipped execution of physical command [AC FAN].off([]) because it would make no change to the device. (7ms)
+91ms ║║Executed [AC FAN].off (10ms)
+102ms ║║Executed virtual command [AC FAN].wait (0ms)
+104ms ║║Requesting a wake up for Sat, Aug 7 2021 @ 12:18:41 PM CEST (in 30.0s)
+114ms ║╚Execution stage complete. (47ms)
+116ms ║Setting up scheduled job for Sat, Aug 7 2021 @ 12:18:41 PM CEST (in 29s)
+123ms ╚Event processed successfully (123ms)
8/7/2021, 12:17:56 PM +62ms
+0ms ╔Received event [Home].time = 1628331477750 with a delay of -1688ms
+62ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 36ms > CE
+64ms ║Runtime (37967 bytes) successfully initialized in 5ms (v0.3.113.20210203) (63ms)
+65ms ║╔Execution stage started
+71ms ║║Cancelling condition #3’s schedules…
+73ms ║║Condition #3 evaluated true (1ms)
+74ms ║║Cancelling condition #1’s schedules…
+75ms ║║Condition group #1 evaluated true (state changed) (4ms)
+78ms ║║Cancelling statement #6’s schedules…
+98ms ║║Executed physical command [AC FAN].on() (16ms)
+100ms ║║Executed [AC FAN].on (17ms)
+105ms ║║Executed virtual command [AC FAN].wait (0ms)
+106ms ║║Waiting for 2000ms
+2279ms ║║Executed physical command [AC FAN].off() (16ms)
+2281ms ║║Executed virtual command [AC FAN].toggle (29ms)
+2288ms ║║Executed virtual command [AC FAN].wait (1ms)
+2290ms ║║Waiting for 2000ms
+4339ms ║║Executed physical command [AC FAN].on() (24ms)
+4340ms ║║Executed virtual command [AC FAN].toggle (46ms)
+4346ms ║║Executed virtual command [AC FAN].wait (1ms)
+4347ms ║║Waiting for 2000ms
+6379ms ║║Executed physical command [AC FAN].off() (17ms)
+6380ms ║║Executed virtual command [AC FAN].toggle (29ms)
+6386ms ║║Executed virtual command [AC FAN].wait (0ms)
+6388ms ║║Requesting a wake up for Sat, Aug 7 2021 @ 12:18:12 PM CEST (in 10.0s)
+6393ms ║╚Execution stage complete. (6328ms)
+6395ms ║Setting up scheduled job for Sat, Aug 7 2021 @ 12:18:12 PM CEST (in 9s)
+6410ms ╚Event processed successfully (6409ms)
8/7/2021, 12:17:47 PM +669ms
+1ms ╔Received event [Air conditioner].switch = on with a delay of 61ms
+57ms ║RunTime Analysis CS > 14ms > PS > 5ms > PE > 38ms > CE
+60ms ║Runtime (37968 bytes) successfully initialized in 5ms (v0.3.113.20210203) (58ms)
+61ms ║╔Execution stage started
+70ms ║║Comparison (enum) on changes_to (string) on = true (0ms)
+71ms ║║Cancelling condition #2’s schedules…
+72ms ║║Condition #2 evaluated true (6ms)
+78ms ║║Comparison (enum) on stays (string) on = true (2ms)
+80ms ║║Adding a timed trigger schedule for condition 3
+83ms ║║Condition #3 evaluated false (9ms)
+84ms ║║Condition group #1 evaluated false (state did not change) (18ms)
+87ms ║╚Execution stage complete. (25ms)
+88ms ║Setting up scheduled job for Sat, Aug 7 2021 @ 12:17:57 PM CEST (in 9s)
+95ms ╚Event processed successfully (95ms)
