new to smartthings and webcore, but trying. setting up a small piston to speak alerts for an exit and entry delays when SHM armed. it works fine if I dont open a door to leave the house. When I open the door, the announcements stop and the virtual switch never gets set to on.
I dont want the top section to be interupted
virtual switch is not getting turned on.
<|+0ms|â•”Received event [Marshad Dr.].alarmSystemStatus = off with a delay of 59ms|
|+120ms|â•‘RunTime Analysis CS > 20ms > PS > 72ms > PE > 29ms > CE|
|+123ms|â•‘Runtime (42282 bytes) successfully initialized in 72ms (v0.3.108.20180906) (122ms)|
|+124ms|â•‘â•”Execution stage started|
|+137ms|â•‘â•‘Comparison (string) off changes_to (string) away = false (1ms)|
|+139ms|â•‘â•‘Condition #2 evaluated false (7ms)|
|+140ms|â•‘â•‘Condition group #1 evaluated false (state did not change) (10ms)|
|+155ms|║║Cancelling condition #21’s schedules…|
|+157ms|â•‘â•‘Condition #21 evaluated false (13ms)|
|+158ms|â•‘â•‘Condition group #19 evaluated false (state did not change) (15ms)|
|+161ms|║╚Execution stage complete. (37ms)|
|+163ms|╚Event processed successfully (163ms)|
|12/12/2018, 11:32:45 AM +150ms|
|+1ms|â•”Received event [Marshad Dr.].time = 1544635966192 with a delay of -1042ms|
|+131ms|â•‘RunTime Analysis CS > 23ms > PS > 77ms > PE > 30ms > CE|
|+134ms|â•‘Runtime (42282 bytes) successfully initialized in 77ms (v0.3.108.20180906) (132ms)|
|+136ms|â•‘â•”Execution stage started|
|+138ms|║╚Execution stage complete. (2ms)|
|+140ms|╚Event processed successfully (140ms)|
|12/12/2018, 11:32:35 AM +889ms|
|+2ms|â•”Received event [Door-Front].contact = open with a delay of 60ms|
|+8699ms|â•‘RunTime Analysis CS > 17ms > PS > 8652ms > PE > 30ms > CE|
|+8701ms|â•‘Piston waited at a semaphore for 8587ms|
|+8704ms|â•‘Runtime (42349 bytes) successfully initialized in 8652ms (v0.3.108.20180906) (8701ms)|
|+8705ms|â•‘â•”Execution stage started|
|+8719ms|â•‘â•‘Comparison (string) away changes_to (string) away = false (1ms)|
|+8722ms|â•‘â•‘Condition #2 evaluated false (9ms)|
|+8723ms|â•‘â•‘Condition group #1 evaluated false (state did not change) (11ms)|
|+8737ms|â•‘â•‘Comparison (enum) open changes = true (2ms)|
|+8740ms|║║Cancelling condition #21’s schedules…|
|+8742ms|â•‘â•‘Condition #21 evaluated true (14ms)|
|+8754ms|â•‘â•‘Comparison (enum) off is (string) on = false (3ms)|
|+8757ms|â•‘â•‘Condition #28 evaluated false (13ms)|
|+8759ms|â•‘â•‘Condition group #19 evaluated false (state did not change) (32ms)|
|+8764ms|║╚Execution stage complete. (58ms)|
|+8766ms|╚Event processed successfully (8765ms)|
|12/12/2018, 11:32:39 AM +454ms|
|+1ms|â•”Received event [Door-Front].contact = closed with a delay of 47ms|
|+103ms|â•‘RunTime Analysis CS > 18ms > PS > 60ms > PE > 26ms > CE|
|+106ms|â•‘Runtime (42272 bytes) successfully initialized in 60ms (v0.3.108.20180906) (104ms)|
|+107ms|â•‘â•”Execution stage started|
|+121ms|â•‘â•‘Comparison (string) away changes_to (string) away = false (1ms)|
|+123ms|║║Cancelling condition #2’s schedules…|
|+124ms|â•‘â•‘Condition #2 evaluated false (10ms)|
|+125ms|║║Cancelling condition #1’s schedules…|
|+127ms|â•‘â•‘Condition group #1 evaluated false (state changed) (13ms)|
|+139ms|â•‘â•‘Comparison (enum) closed changes = false (0ms)|
|+141ms|â•‘â•‘Condition #21 evaluated false (11ms)|
|+142ms|â•‘â•‘Condition group #19 evaluated false (state did not change) (13ms)|
|+146ms|║╚Execution stage complete. (39ms)|
|+148ms|╚Event processed successfully (148ms)|
|12/12/2018, 11:32:34 AM +246ms|
|+0ms|â•”Received event [Marshad Dr.].time = 1544635955201 with a delay of -956ms|
|+119ms|â•‘RunTime Analysis CS > 21ms > PS > 69ms > PE > 29ms > CE|
|+121ms|â•‘Runtime (42279 bytes) successfully initialized in 69ms (v0.3.108.20180906) (119ms)|
|+123ms|â•‘â•”Execution stage started|
|+1838ms|â•‘â•‘Executed physical command [Echo - Main Display].speak([Alarm is arming, you have 50 seconds to leave the house.]) (1691ms)|
|+1840ms|â•‘â•‘Executed [Echo - Main Display].speak (1694ms)|
|+1936ms|â•‘â•‘Executed physical command [Echo - Utility Tablet].speak([Alarm is arming, you have 50 seconds to leave the house.]) (92ms)|
|+1937ms|â•‘â•‘Executed [Echo - Utility Tablet].speak (94ms)|
|+1943ms|â•‘â•‘Executed virtual command [Echo - Main Display, Echo - Utility Tablet].wait (1ms)|
|+1945ms|â•‘â•‘Requesting a wake up for Wed, Dec 12 2018 @ 11:32:46 AM CST (in 10.0s)|
|+1953ms|║╚Execution stage complete. (1831ms)|
|+1956ms|â•‘Setting up scheduled job for Wed, Dec 12 2018 @ 11:32:46 AM CST (in 9.992s)|
|+1965ms|╚Event processed successfully (1964ms)|
|12/12/2018, 11:32:24 AM +563ms|
|+0ms|â•”Received event [Marshad Dr.].alarmSystemStatus = away with a delay of 73ms|
|+130ms|â•‘RunTime Analysis CS > 20ms > PS > 72ms > PE > 38ms > CE|
|+132ms|â•‘Runtime (42283 bytes) successfully initialized in 72ms (v0.3.108.20180906) (131ms)|
|+134ms|â•‘â•”Execution stage started|
|+147ms|â•‘â•‘Comparison (string) away changes_to (string) away = true (1ms)|
|+149ms|║║Cancelling condition #2’s schedules…|
|+150ms|â•‘â•‘Condition #2 evaluated true (10ms)|
|+152ms|║║Cancelling condition #1’s schedules…|
|+153ms|â•‘â•‘Condition group #1 evaluated true (state changed) (13ms)|
|+158ms|║║Cancelling statement #4’s schedules…|
|+235ms|â•‘â•‘Executed physical command [Echo - Main Display].setLevel([75]) (70ms)|
|+236ms|â•‘â•‘Executed [Echo - Main Display].setLevel (71ms)|
|+444ms|â•‘â•‘Executed physical command [Echo - Utility Tablet].setLevel([75]) (202ms)|
|+445ms|â•‘â•‘Executed [Echo - Utility Tablet].setLevel (205ms)|
|+553ms|â•‘â•‘Executed physical command [Echo - Main Display].speak([Alarm is arming, you have 60 seconds to leave the house.]) (102ms)|
|+554ms|â•‘â•‘Executed [Echo - Main Display].speak (106ms)|
|+630ms|â•‘â•‘Executed physical command [Echo - Utility Tablet].speak([Alarm is arming, you have 60 seconds to leave the house.]) (72ms)|
|+631ms|â•‘â•‘Executed [Echo - Utility Tablet].speak (75ms)|
|+636ms|â•‘â•‘Executed virtual command [Echo - Main Display, Echo - Utility Tablet].wait (1ms)|
|+637ms|â•‘â•‘Requesting a wake up for Wed, Dec 12 2018 @ 11:32:35 AM CST (in 10.0s)|
|+643ms|║╚Execution stage complete. (510ms)|
|+645ms|â•‘Setting up scheduled job for Wed, Dec 12 2018 @ 11:32:35 AM CST (in 9.994s)|
|+654ms|╚Event processed successfully (653ms)|Preformatted text>
