I have a couple of pistons that control my Kitchen skylight blinds based on
a. the time of year and then
b. the amount of sunlight actually hitting the window and the time of day, temp, etc
One of the pistons is for Spring and Fall and the other for Summer. The Spring and Fall piston is number one in my Hubitat use of resources right now and it is not even the time of year where it is triggering!
There must be a simple answer to this but how to I redesign this Piston to take up less resources? I would have thought that he âonly whenâ command would be the first evaluated and if false then not look at any more of the Piston but that is evidently not the case. Is there a way in a piston to just evaluate a single trigger (in my case time of year) and if false do nothing else?
