Hi,
I have a piston that changes the color of 4 bulbs until a variable is changed.
If the piston is running and I press the button, it takes ~5 seconds to stop its actions.
The button also triggers a switch and I can see the same delay there. It seems that somehow it throttles Smartthings.
I am not sure what I am doing wrong and also I don’t know about Smartthings limitations.
Any help would be much appreciated.
Here is the piston:
Thank you!
