Trying to create a piston to open several shades to there preset position at the same time every day)
(All shades listed will open to preset at the given time the piston is to trigger and open at the preset position
Only the Family Room Left Shade is opening on this piston, the Center and Right are not. When I change to just list one of those shades, the piston executes successfully.)
7/9/2018, 8:33:05 PM +524ms
+1ms ╔Received event [Home].test = 1531186385523 with a delay of 0ms
+140ms ║RunTime Analysis CS > 16ms > PS > 111ms > PE > 13ms > CE
+143ms ║Runtime (36695 bytes) successfully initialized in 111ms (v0.3.105.20180628) (142ms)
+151ms ║║Condition group #1 evaluated true (state did not change) (0ms)
+153ms ║║Cancelling statement #2’s schedules…
+323ms ║║Executed physical command [Family Room Left Shade].presetPosition() (164ms)
+324ms ║║Executed [Family Room Left Shade].presetPosition (169ms)
+327ms ║║Cancelling statement #4’s schedules…
+335ms ║║Skipped execution of physical command [Family Room Center Shade].presetPosition([]) because it would make no change to the device. (3ms)
+336ms ║║Executed [Family Room Center Shade].presetPosition (5ms)
+338ms ║║Cancelling statement #6’s schedules…
+344ms ║║Skipped execution of physical command [Family Room Right Shade].presetPosition([]) because it would make no change to the device. (2ms)
+345ms ║║Executed [Family Room Right Shade].presetPosition (4ms)
+347ms ║╚Execution stage complete. (203ms)
+349ms ╚Event processed successfully (350ms)
