I’m using a piston for a motion sensor. When I only use a single argument in the “if” section, the piston performs the action in the “then” section without an issue. If I add an additional argument in the “if” section, it no longer triggers the action in the “then” section. I believe the logic I’m using is correct, but it’s not working for some reason, and I’m unsure why.
I would like to receive a PUSH alert if the motion sensor no longer detects motion for 45 seconds. I would like for the action in the "then" section to execute when I use two arguments in the "if" section.
When I use two arguments in the “if” section, the action in the “then” section doesn’t successfully execute.
(1/30/2019, 1:13:08 PM +361ms
+2ms	╔Received event [Dryer Sensor].motion = inactive with a delay of 927ms
+10188ms	║RunTime Analysis CS > 21ms > PS > 10121ms > PE > 46ms > CE
+10190ms	║Piston waited at a semaphore for 10058ms
+10192ms	║Runtime (37472 bytes) successfully initialized in 10121ms (v0.3.109.20181207) (10188ms)
+10193ms	║╔Execution stage started
+10204ms	║║Comparison (enum) inactive changes_to (string) inactive = false (1ms)
+10206ms	║║Cancelling condition #2’s schedules…
+10207ms	║║Condition #2 evaluated false (7ms)
+10209ms	║║Cancelling statement #1’s schedules…
+10210ms	║║Condition group #1 evaluated false (state did not change) (11ms)
+10213ms	║╚Execution stage complete. (21ms)
+10215ms	╚Event processed successfully (10215ms)
1/30/2019, 1:13:08 PM +352ms
+2ms	╔Received event [Dryer Sensor].motion = inactive with a delay of 868ms
+122ms	║RunTime Analysis CS > 25ms > PS > 55ms > PE > 41ms > CE
+124ms	║Runtime (37391 bytes) successfully initialized in 55ms (v0.3.109.20181207) (121ms)
+125ms	║╔Execution stage started
+137ms	║║Comparison (enum) inactive changes_to (string) inactive = true (1ms)
+139ms	║║Cancelling condition #2’s schedules…
+140ms	║║Condition #2 evaluated true (7ms)
+141ms	║║Cancelling statement #1’s schedules…
+142ms	║║Condition group #1 made progress up the ladder, currently at step 1 of 2
+149ms	║║Fast executing schedules, waiting for 996ms to sync up
+1154ms	║║Conditional ladder step failed due to a timeout
+1155ms	║║Cancelling statement #1’s schedules…
+1157ms	║║Condition group #1 evaluated false (state did not change) (5ms)
+1159ms	║╚Execution stage complete. (1034ms)
+1160ms	╚Event processed successfully (1160ms)
1/30/2019, 1:12:04 PM +868ms
+1ms	╔Received event [Dryer Sensor].motion = active with a delay of 894ms
+84ms	║RunTime Analysis CS > 23ms > PS > 31ms > PE > 29ms > CE
+86ms	║Runtime (37390 bytes) successfully initialized in 31ms (v0.3.109.20181207) (84ms)
+88ms	║╔Execution stage started
+98ms	║║Comparison (enum) active changes_to (string) inactive = false (1ms)
+100ms	║║Condition #2 evaluated false (5ms)
+101ms	║║Cancelling statement #1’s schedules…
+102ms	║║Condition group #1 evaluated false (state did not change) (9ms)
+104ms	║╚Execution stage complete. (17ms)
+106ms	╚Event processed successfully (106ms)
