Using RBOY Lock DTH and triggering a IFTTT Maker Event to start WyzeCam recording but triggering more often than it should. RBOY told me to check WebCore as it works appropriately in Smartthings.
When the Lock Code #1 is used, send the IFTTT Maker Event to trigger recording. This allows me to record a short video when someone uses the front door code.
When there is a programatic unlock (i.e. routine, piston, etc.) or the unlock code #1 is used it is triggering this piston. It should only occur when code #1 is used.
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:35 AM: info [DTH] parse() - returning result=[[name:alarm, value:forced, descriptionText:Alarm mode forced, linkText:Front Door Lock, isStateChange:false, displayed:false]]
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:35 AM: trace ConfigurationReport ConfigurationReport(parameterNumber: 7, scaledConfigurationValue: 3, reserved11: 0, size: 1, configurationValue: [3])
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:32 AM: info [DTH] parse() - returning result=[[name:codeLength, value:4, descriptionText:Code length is 4, displayed:false, linkText:Front Door Lock, isStateChange:false]]
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:32 AM: trace [DTH] Executing ‘ConfigurationReport’ for device Front Door Lock with code length := 4
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:32 AM: trace ConfigurationReport ConfigurationReport(parameterNumber: 16, scaledConfigurationValue: 4, reserved11: 0, size: 1, configurationValue: [4])
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:30 AM: info [DTH] parse() - returning result=[name:lock, data:[lockName:Front Door Lock], value:unlocked, descriptionText:Unlocked, linkText:Front Door Lock, isStateChange:true, displayed:true]
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:30 AM: trace [DTH] Executing ‘zwaveEvent(DoorLockOperationReport)’ with cmd = DoorLockOperationReport(lockTimeoutMinutes: 254, doorLockMode: 0, insideDoorHandlesMode: 0, doorCondition: 2, outsideDoorHandlesMode: 0, lockTimeoutSeconds: 254)
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:28 AM: info [DTH] parse() - returning result=[[descriptionText:Is associated, linkText:Front Door Lock, isStateChange:false, displayed:false]]
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:28 AM: trace [DTH] Executing ‘zwaveEvent(physicalgraph.zwave.commands.associationv2.AssociationReport)’ with cmd = AssociationReport(reportsToFollow: 0, maxNodesSupported: 2, nodeId: [1], groupingIdentifier: 1)
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:22 AM: trace [DTH] Executing unlock() for device Front Door Lock
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:11 AM: trace Found Schlage
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:11 AM: debug Getting Sensitivity Level, current Alarm Mode forced
53ec4eb8-a0b9-4af7-9513-30d2cecaaa77 10:02:11 AM: debug Getting Alarm Level
