This piston has been working pretty well for a few days. Today, however, it did not fire for some reason.
Looks like triggers are not being evaluated incorrectly (bolded by me in the logs).
Plug should turn on when temperature drops below certain point.
It is not turning on
1/17/2021, 6:41:17 AM +669ms
+1ms ╔Received event [Temp Bedroom].temperature = 62 with a delay of 79ms
+83ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 57ms > CE
+85ms ║Runtime (39078 bytes) successfully initialized in 5ms (v0.3.110.20191009) (83ms)
+86ms ║╔Execution stage started
+106ms ║║Comparison (string) Sleep is_any_of (string) PreSleep, Sleep = true (2ms)
+107ms ║║Condition #22 evaluated true (18ms)
+117ms ║║Comparison (enum) heat is_any_of (string) auto,heat,off = true (2ms)
+119ms ║║Condition #23 evaluated true (10ms)
+127ms ║║Comparison (decimal) 43.8 is_less_than (integer) 65 = true (1ms)
+128ms ║║Condition #24 evaluated true (9ms)
+129ms ║║Condition group #null evaluated true (state did not change) (40ms)
+134ms ║║Comparison (decimal) 62.0 drops_to_or_below (integer) 65 = false (1ms)
+135ms ║║Condition #15 evaluated false (4ms)
+136ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+140ms ║║Comparison (decimal) 62.0 rises_to_or_above (integer) 68 = false (1ms)
+142ms ║║Condition #26 evaluated false (5ms)
+143ms ║║Condition group #25 evaluated false (state did not change) (6ms)
+144ms ║╚Execution stage complete. (58ms)
+146ms ╚Event processed successfully (145ms)
1/17/2021, 6:00:18 AM +685ms
+2ms ╔Received event [Temp Bedroom].temperature = 63 with a delay of 98ms
+71ms ║RunTime Analysis CS > 22ms > PS > 5ms > PE > 44ms > CE
+73ms ║Runtime (39078 bytes) successfully initialized in 5ms (v0.3.110.20191009) (70ms)
+92ms ║║Comparison (string) Sleep is_any_of (string) PreSleep, Sleep = true (2ms)
+93ms ║║Condition #22 evaluated true (16ms)
+104ms ║║Comparison (enum) heat is_any_of (string) auto,heat,off = true (1ms)
+105ms ║║Condition #23 evaluated true (11ms)
+114ms ║║Comparison (decimal) 44.8 is_less_than (integer) 65 = true (1ms)
+115ms ║║Condition #24 evaluated true (10ms)
+116ms ║║Condition group #null evaluated true (state did not change) (38ms)
+120ms ║║Comparison (decimal) 63.0 drops_to_or_below (integer) 65 = false (1ms)
+121ms ║║Condition #15 evaluated false (4ms)
+122ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+126ms ║║Comparison (decimal) 63.0 rises_to_or_above (integer) 68 = false (0ms)
+127ms ║║Condition #26 evaluated false (4ms)
+128ms ║║Condition group #25 evaluated false (state did not change) (4ms)
+129ms ║╚Execution stage complete. (55ms)
+130ms ╚Event processed successfully (130ms)
