I’ve created a piston to control the fan in my living room based on an Ecobee thermostat’s operating state, OR the temperature in the room. I want to set the fan speed to medium if the HVAC system is either cooling or heating. If neither is happening, I set it to speed based on temperature when there is motion in the room. When I start the piston I am getting the following error:
An error has occurred while subscribing: groovy.lang.MissingPropertyException: No such property: r for class: java.lang.Boolean
The piston should subscribe to events such as the thermostat operatingstate changing, motion, and temperature
I’m getting the error message mentioned above and the piston is not subscribing to any events.
10/17/2018, 11:30:05 AM +303ms
+1ms ╔Starting piston… (v0.3.108.20180906)
+570ms ║╔Subscribing to devices…
+575ms ║║An error has occurred while subscribing: groovy.lang.MissingPropertyException: No such property: r for class: java.lang.Boolean
+578ms ║╚Piston successfully started (577ms)
