I have a fairly complex piston that will set variables for brightness and color temperature for my bulbs depending on time of day. It was all working fine, then something locked up while I was saving the piston. I had to clear the cache in the ST webCoRE app to get the piston to load again.
Well, now my piston isn’t working (variables aren’t changing) and my Log is empty. I had previously had the Log set to “Medium” level and was getting some useful info. I’ve tried changing the logging level and no help.
I’m left with a piston that won’t work and an empty log so I can’t figure out what the problem is!
Any insight?
