I moved a piston over from ST to Hubitat. After bringing it up from a backup file, I updated all the device references. Everything looked good.
Saved it, it’s listed on the page of pistons, in paused state.
When I click on it, it will not load- just spins as if it is loading indefintely. Can’t even get to the main piston page, let alone the editing page. I can get to other pistons.
It is possible that I messed this up when I was switching back and forth between ST and HE…
- Backed up piston in ST Dashboard
- Switched to HE Dashboard and imported
- Opened New Piston and edited to update devices
- opened a new tab to Webcore, changed that one to ST and brought up the old piston to see the devices
- Updated devices in the New Piston Tab.
- When done, saved… but the last Webcore system I had selected was the ST system in the other tab. Maybe this was a mistake, and hitting save on a piston opened in HE after switching to ST in another tab of the same browser session did something bad?
Hubitat App info:
### Application Info
Piston is paused
Automatic backup bin code:
Version: v0.3.110.20191009
VersionH: v0.3.110.20201015_HE
Memory Usage: 0% (211 bytes)
RunTime History: Total run history: []
Last run details: null
