I rewired my dehumidifier over a year ago with a contact sensor so that I could get notifications when the tank was full. This worked for over a year without any problems at all. I haven’t made any changes to webcore in months, but in the recent weeks, I noticed I was no longer getting notifications. The setup works like this:
Piston A subscribes to the contact change and if the contact changes, waits 5 mins. If the contact has remain changed after 5 mins, it would “Execute Piston B”.
Piston B was responsible for Pausing Piston A and then checking on the contact sensor every hour and sending SMS notifications to my kids to tell them to dump the dehumidifier. When the contact changed, it would execute Piston A again (which would Pause B)
This worked awesome for a year - my house was dry
! Now, it’s wet
I can no longer execute one piston from another
The second Piston stays in the Paused State
8/4/2020, 7:02:20 PM +46ms
+1ms ╔Received event [Hidden Stream].time = 1596582141719 with a delay of -1673ms
+76ms ║RunTime Analysis CS > 18ms > PS > 44ms > PE > 14ms > CE
+79ms ║Runtime (38784 bytes) successfully initialized in 44ms (v0.3.110.20191009) (77ms)
+98ms ║║open
+99ms ║║Executed virtual command log (2ms)
+111ms ║║Comparison (enum) open is (string) open = true (1ms)
+112ms ║║Cancelling condition #8’s schedules…
+113ms ║║Condition #8 evaluated true (11ms)
+115ms ║║Cancelling condition #7’s schedules…
+115ms ║║Condition group #7 evaluated true (state changed) (14ms)
+118ms ║║Cancelling statement #9’s schedules…
+125ms ║║Piston should have fired
+126ms ║║Executed virtual command log (1ms)
+140ms ║║Executed virtual command executePiston (10ms)
+143ms ║╚Execution stage complete. (63ms)
+145ms ╚Event processed successfully (145ms)
8/4/2020, 6:57:21 PM +641ms
+1ms ╔Received event [Dehumidifier].contact = open with a delay of 37ms
+56ms ║RunTime Analysis CS > 14ms > PS > 32ms > PE > 10ms > CE
+58ms ║Runtime (38778 bytes) successfully initialized in 32ms (v0.3.110.20191009) (56ms)
+59ms ║╔Execution stage started
+66ms ║║Comparison (enum) open changes_to (string) open = true (0ms)
+68ms ║║Cancelling condition #2’s schedules…
+69ms ║║Condition #2 evaluated true (6ms)
+70ms ║║Cancelling condition #1’s schedules…
+71ms ║║Condition group #1 evaluated true (state changed) (8ms)
+73ms ║║Cancelling statement #5’s schedules…
+76ms ║║Executed virtual command wait (1ms)
+77ms ║║Requesting a wake up for Tue, Aug 4 2020 @ 7:02:21 PM EDT (in 300.0s)
+81ms ║╚Execution stage complete. (22ms)
+82ms ║Setting up scheduled job for Tue, Aug 4 2020 @ 7:02:21 PM EDT (in 299.996s)
+90ms ╚Event processed successfully (90ms)
8/4/2020, 6:57:19 PM +190ms
+1ms ╔Received event [Hidden Stream].test = 1596581839190 with a delay of 0ms
+65ms ║RunTime Analysis CS > 14ms > PS > 32ms > PE > 18ms > CE
+67ms ║Runtime (38784 bytes) successfully initialized in 32ms (v0.3.110.20191009) (65ms)
+81ms ║║Condition #2 evaluated false (8ms)
+83ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+86ms ║╚Execution stage complete. (18ms)
+88ms ╚Event processed successfully (88ms)
