I’ve noticed that several of my pistons have started to only fire once in a while, or in some cases not completely. And I am wondering if I am running into a memory issue or similiar.
In this example the Button was physically held but nothing happened, pressing it works fine and trying to trigger the Zzzz routine manually didn’t produce any results either.
Holding down the Button should trigger the location mode change to Zzzz and that in turn should trigger another piston.
Button is being held, nothing happens.
Location Mode Change to Zzzz log
9.3.2021 11.19.35 +202ms
+1ms ╔Starting piston… (v0.3.113.20210203)
+596ms ║╔Subscribing to devices…
+605ms ║║Subscribing to Home.mode…
+795ms ║║Subscribing to Børneværelse Loft…
+796ms ║║Subscribing to Børneværelset 2…
+797ms ║║Subscribing to Entre 1…
+798ms ║║Subscribing to Entre 2…
+800ms ║║Subscribing to Køkken Lille Lampe 1 Bridge…
+801ms ║║Subscribing to Køkken Lille Lampe 2…
+802ms ║║Subscribing to Lyskæde…
+803ms ║║Subscribing to Reol Lampe…
+804ms ║║Subscribing to Reol Lampe 2…
+805ms ║║Subscribing to Rund Lampe…
+806ms ║║Subscribing to Skuret 1…
+807ms ║║Subscribing to Skuret 2…
+808ms ║║Subscribing to Skuret udenfor 1…
+809ms ║║Subscribing to Skuret udenfor 2…
+811ms ║║Subscribing to Skuret udenfor 3…
+812ms ║║Subscribing to Soveværelset Ny…
+813ms ║║Subscribing to Spisebordet 1…
+814ms ║║Subscribing to Spisebordet 2…
+815ms ║║Subscribing to Standerlampe 2…
+816ms ║║Subscribing to Stuen - Lille lampe…
+817ms ║║Subscribing to Stuen - Standerlampe 1…
+818ms ║║Subscribing to Stuen Loftslampe…
+819ms ║║Subscribing to Udestuen…
+820ms ║║Subscribing to Havedøren (Kamera)…
+821ms ║║Subscribing to Skuret (Kamera)…
+823ms ║║Subscribing to Udenfor (Kamera)…
+824ms ║║Subscribing to Hue Go…
+825ms ║╚Finished subscribing (242ms)
+851ms ║Comparison (string) :b642fe37bf906f8dc735b9c8b79b57d5: changes_to (string) :2bb8359ad700d5d6ed3a4f4fc2189689: = false (1ms)
+872ms ╚Piston successfully started (872ms)
Button being held piston log
11.3.2021 17.53.52 +391ms
+1ms ╔Received event [Button Soveværelset].button = pushed with a delay of 64ms
+65ms ║RunTime Analysis CS > 19ms > PS > 8ms > PE > 38ms > CE
+67ms ║Runtime (40196 bytes) successfully initialized in 8ms (v0.3.113.20210203) (65ms)
+75ms ║║Comparison (enum) pushed gets (string) pushed = true (0ms)
+77ms ║║Condition #2 evaluated true (5ms)
+78ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+83ms ║║Comparison (integer) 0 is_even = true (1ms)
+84ms ║║Condition #11 evaluated true (4ms)
+85ms ║║Condition group #10 evaluated true (state did not change) (6ms)
+87ms ║║Cancelling statement #13’s schedules…
+107ms ║║Executed physical command [Sengen].setLevel([30]) (15ms)
+108ms ║║Executed [Sengen].setLevel (17ms)
+116ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (4ms)
+116ms ║║Executed [Sengen].setColorTemperature (5ms)
+122ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+125ms ║║Executed virtual command [Sengen].setVariable (1ms)
+131ms ║║Comparison (integer) 1 is_odd = true (1ms)
+132ms ║║Condition #22 evaluated true (3ms)
+133ms ║║Condition group #21 evaluated true (state did not change) (5ms)
+135ms ║║Cancelling statement #3’s schedules…
+142ms ║║Skipped execution of physical command [Sengen].off([]) because it would make no change to the device. (4ms)
+143ms ║║Executed [Sengen].off (6ms)
+148ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+151ms ║║Executed virtual command [Sengen].setVariable (1ms)
+158ms ║║Comparison (enum) pushed gets (string) held = false (1ms)
+159ms ║║Condition #17 evaluated false (4ms)
+160ms ║║Condition group #16 evaluated false (state did not change) (6ms)
+162ms ║╚Execution stage complete. (94ms)
+163ms ╚Event processed successfully (163ms)
10.3.2021 22.27.16 +964ms
+1ms ╔Received event [Button Soveværelset].button = pushed with a delay of 44ms
+54ms ║RunTime Analysis CS > 17ms > PS > 6ms > PE > 31ms > CE
+57ms ║Runtime (40196 bytes) successfully initialized in 6ms (v0.3.113.20210203) (55ms)
+57ms ║╔Execution stage started
+64ms ║║Comparison (enum) pushed gets (string) pushed = true (1ms)
+65ms ║║Condition #2 evaluated true (4ms)
+66ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+71ms ║║Comparison (integer) 0 is_even = true (1ms)
+72ms ║║Condition #11 evaluated true (4ms)
+73ms ║║Condition group #10 evaluated true (state did not change) (5ms)
+75ms ║║Cancelling statement #13’s schedules…
+85ms ║║Skipped execution of physical command [Sengen].setLevel([30]) because it would make no change to the device. (5ms)
+85ms ║║Executed [Sengen].setLevel (7ms)
+92ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (4ms)
+93ms ║║Executed [Sengen].setColorTemperature (5ms)
+99ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+102ms ║║Executed virtual command [Sengen].setVariable (0ms)
+106ms ║║Comparison (integer) 1 is_odd = true (1ms)
+107ms ║║Condition #22 evaluated true (3ms)
+108ms ║║Condition group #21 evaluated true (state did not change) (4ms)
+110ms ║║Cancelling statement #3’s schedules…
+118ms ║║Executed physical command [Sengen].off() (6ms)
+119ms ║║Executed [Sengen].off (7ms)
+124ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+127ms ║║Executed virtual command [Sengen].setVariable (1ms)
+133ms ║║Comparison (enum) pushed gets (string) held = false (0ms)
+134ms ║║Condition #17 evaluated false (4ms)
+135ms ║║Condition group #16 evaluated false (state did not change) (6ms)
+137ms ║╚Execution stage complete. (79ms)
+138ms ╚Event processed successfully (137ms)
10.3.2021 22.05.13 +86ms
+1ms ╔Received event [Button Soveværelset].button = pushed with a delay of 73ms
+59ms ║RunTime Analysis CS > 19ms > PS > 8ms > PE > 33ms > CE
+62ms ║Runtime (40196 bytes) successfully initialized in 8ms (v0.3.113.20210203) (60ms)
+63ms ║╔Execution stage started
+70ms ║║Comparison (enum) pushed gets (string) pushed = true (0ms)
+71ms ║║Condition #2 evaluated true (4ms)
+72ms ║║Condition group #1 evaluated true (state did not change) (6ms)
+77ms ║║Comparison (integer) 0 is_even = true (0ms)
+78ms ║║Condition #11 evaluated true (4ms)
+79ms ║║Condition group #10 evaluated true (state did not change) (6ms)
+81ms ║║Cancelling statement #13’s schedules…
+99ms ║║Executed physical command [Sengen].setLevel([30]) (14ms)
+100ms ║║Executed [Sengen].setLevel (15ms)
+108ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (5ms)
+109ms ║║Executed [Sengen].setColorTemperature (5ms)
+114ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+117ms ║║Executed virtual command [Sengen].setVariable (1ms)
+122ms ║║Comparison (integer) 1 is_odd = true (1ms)
+123ms ║║Condition #22 evaluated true (3ms)
+124ms ║║Condition group #21 evaluated true (state did not change) (4ms)
+126ms ║║Cancelling statement #3’s schedules…
+133ms ║║Skipped execution of physical command [Sengen].off([]) because it would make no change to the device. (4ms)
+134ms ║║Executed [Sengen].off (6ms)
+139ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+141ms ║║Executed virtual command [Sengen].setVariable (1ms)
+147ms ║║Comparison (enum) pushed gets (string) held = false (0ms)
+149ms ║║Condition #17 evaluated false (4ms)
+150ms ║║Condition group #16 evaluated false (state did not change) (5ms)
+151ms ║╚Execution stage complete. (88ms)
+152ms ╚Event processed successfully (152ms)
10.3.2021 22.05.10 +838ms
+1ms ╔Received event [Button Soveværelset].button = pushed with a delay of 46ms
+52ms ║RunTime Analysis CS > 16ms > PS > 6ms > PE > 29ms > CE
+54ms ║Runtime (40191 bytes) successfully initialized in 6ms (v0.3.113.20210203) (52ms)
+55ms ║╔Execution stage started
+62ms ║║Comparison (enum) pushed gets (string) pushed = true (1ms)
+63ms ║║Cancelling condition #2’s schedules…
+64ms ║║Condition #2 evaluated true (5ms)
+65ms ║║Cancelling condition #1’s schedules…
+66ms ║║Condition group #1 evaluated true (state changed) (7ms)
+76ms ║║Cancelling statement #13’s schedules…
+158ms ║║Skipped execution of physical command [Sengen].setLevel([30]) because it would make no change to the device. (7ms)
+159ms ║║Executed [Sengen].setLevel (8ms)
+165ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (3ms)
+166ms ║║Executed [Sengen].setColorTemperature (5ms)
+172ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+175ms ║║Executed virtual command [Sengen].setVariable (1ms)
+179ms ║║Comparison (integer) 1 is_odd = true (1ms)
+181ms ║║Condition #22 evaluated true (3ms)
+181ms ║║Condition group #21 evaluated true (state did not change) (4ms)
+184ms ║║Cancelling statement #3’s schedules…
+192ms ║║Executed physical command [Sengen].off() (5ms)
+193ms ║║Executed [Sengen].off (7ms)
+197ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+200ms ║║Executed virtual command [Sengen].setVariable (1ms)
+206ms ║║Comparison (enum) pushed gets (string) held = false (1ms)
+208ms ║║Cancelling condition #17’s schedules…
+208ms ║║Condition #17 evaluated false (5ms)
+209ms ║║Cancelling condition #16’s schedules…
+210ms ║║Condition group #16 evaluated false (state changed) (7ms)
+212ms ║╚Execution stage complete. (157ms)
+213ms ╚Event processed successfully (213ms)
10.3.2021 22.05.04 +10ms
+1ms ╔Received event [Button Soveværelset].button = held with a delay of 76ms
+69ms ║RunTime Analysis CS > 25ms > PS > 9ms > PE > 36ms > CE
+72ms ║Runtime (40194 bytes) successfully initialized in 9ms (v0.3.113.20210203) (69ms)
+72ms ║╔Execution stage started
+80ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+82ms ║║Cancelling condition #2’s schedules…
+83ms ║║Condition #2 evaluated false (6ms)
+84ms ║║Cancelling condition #1’s schedules…
+85ms ║║Condition group #1 evaluated false (state changed) (7ms)
+91ms ║║Comparison (enum) held gets (string) held = true (0ms)
+92ms ║║Cancelling condition #17’s schedules…
+93ms ║║Condition #17 evaluated true (6ms)
+95ms ║║Cancelling condition #16’s schedules…
+96ms ║║Condition group #16 evaluated true (state changed) (9ms)
+98ms ║║Cancelling statement #18’s schedules…
+124ms ║║Executed virtual command setLocationMode (23ms)
+127ms ║╚Execution stage complete. (55ms)
+129ms ╚Event processed successfully (129ms)
10.3.2021 22.04.59 +464ms
+1ms ╔Received event [Button Soveværelset].button = pushed with a delay of 62ms
+52ms ║RunTime Analysis CS > 18ms > PS > 7ms > PE > 28ms > CE
+54ms ║Runtime (40196 bytes) successfully initialized in 7ms (v0.3.113.20210203) (53ms)
+61ms ║║Comparison (enum) pushed gets (string) pushed = true (0ms)
+63ms ║║Condition #2 evaluated true (3ms)
+63ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+68ms ║║Comparison (integer) 0 is_even = true (1ms)
+69ms ║║Condition #11 evaluated true (4ms)
+70ms ║║Condition group #10 evaluated true (state did not change) (5ms)
+72ms ║║Cancelling statement #13’s schedules…
+89ms ║║Executed physical command [Sengen].setLevel([30]) (13ms)
+90ms ║║Executed [Sengen].setLevel (14ms)
+95ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (2ms)
+96ms ║║Executed [Sengen].setColorTemperature (4ms)
+102ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+104ms ║║Executed virtual command [Sengen].setVariable (1ms)
+109ms ║║Comparison (integer) 1 is_odd = true (1ms)
+110ms ║║Condition #22 evaluated true (3ms)
+111ms ║║Condition group #21 evaluated true (state did not change) (4ms)
+113ms ║║Cancelling statement #3’s schedules…
+119ms ║║Skipped execution of physical command [Sengen].off([]) because it would make no change to the device. (4ms)
+120ms ║║Executed [Sengen].off (6ms)
+132ms ║║Comparison (enum) pushed gets (string) held = false (0ms)
+134ms ║║Condition #17 evaluated false (3ms)
+135ms ║║Condition group #16 evaluated false (state did not change) (5ms)
+136ms ║╚Execution stage complete. (81ms)
+137ms ╚Event processed successfully (137ms)
10.3.2021 22.04.56 +311ms
+0ms ╔Received event [Button Soveværelset].button = pushed with a delay of 41ms
+57ms ║RunTime Analysis CS > 17ms > PS > 7ms > PE > 33ms > CE
+59ms ║Runtime (40191 bytes) successfully initialized in 7ms (v0.3.113.20210203) (58ms)
+60ms ║╔Execution stage started
+67ms ║║Comparison (enum) pushed gets (string) pushed = true (1ms)
+68ms ║║Cancelling condition #2’s schedules…
+69ms ║║Condition #2 evaluated true (5ms)
+70ms ║║Cancelling condition #1’s schedules…
+71ms ║║Condition group #1 evaluated true (state changed) (8ms)
+76ms ║║Comparison (integer) 0 is_even = true (0ms)
+77ms ║║Condition #11 evaluated true (4ms)
+78ms ║║Condition group #10 evaluated true (state did not change) (6ms)
+80ms ║║Cancelling statement #13’s schedules…
+91ms ║║Skipped execution of physical command [Sengen].setLevel([30]) because it would make no change to the device. (7ms)
+92ms ║║Executed [Sengen].setLevel (8ms)
+98ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (4ms)
+99ms ║║Executed [Sengen].setColorTemperature (5ms)
+105ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+107ms ║║Executed virtual command [Sengen].setVariable (1ms)
+112ms ║║Comparison (integer) 1 is_odd = true (1ms)
+113ms ║║Condition #22 evaluated true (3ms)
+114ms ║║Condition group #21 evaluated true (state did not change) (4ms)
+116ms ║║Cancelling statement #3’s schedules…
+125ms ║║Executed physical command [Sengen].off() (7ms)
+126ms ║║Executed [Sengen].off (7ms)
+130ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+133ms ║║Executed virtual command [Sengen].setVariable (1ms)
+139ms ║║Comparison (enum) pushed gets (string) held = false (1ms)
+140ms ║║Cancelling condition #17’s schedules…
+141ms ║║Condition #17 evaluated false (5ms)
+142ms ║║Cancelling condition #16’s schedules…
+143ms ║║Condition group #16 evaluated false (state changed) (7ms)
+145ms ║╚Execution stage complete. (84ms)
+146ms ╚Event processed successfully (146ms)
10.3.2021 22.04.52 +980ms
+1ms ╔Received event [Button Soveværelset].button = held with a delay of 68ms
+54ms ║RunTime Analysis CS > 19ms > PS > 8ms > PE > 28ms > CE
+56ms ║Runtime (40189 bytes) successfully initialized in 8ms (v0.3.113.20210203) (54ms)
+64ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+65ms ║║Condition #2 evaluated false (4ms)
+66ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+71ms ║║Comparison (enum) held gets (string) held = true (0ms)
+73ms ║║Condition #17 evaluated true (4ms)
+74ms ║║Condition group #16 evaluated true (state did not change) (6ms)
+76ms ║║Cancelling statement #18’s schedules…
+107ms ║║Executed virtual command setLocationMode (29ms)
+109ms ║╚Execution stage complete. (52ms)
+110ms ╚Event processed successfully (110ms)
10.3.2021 22.04.46 +671ms
+1ms ╔Received event [Button Soveværelset].button = held with a delay of 66ms
+71ms ║RunTime Analysis CS > 21ms > PS > 8ms > PE > 41ms > CE
+73ms ║Runtime (40189 bytes) successfully initialized in 8ms (v0.3.113.20210203) (71ms)
+83ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+85ms ║║Condition #2 evaluated false (4ms)
+86ms ║║Condition group #1 evaluated false (state did not change) (7ms)
+92ms ║║Comparison (enum) held gets (string) held = true (1ms)
+94ms ║║Condition #17 evaluated true (5ms)
+95ms ║║Condition group #16 evaluated true (state did not change) (7ms)
+119ms ║║Executed virtual command setLocationMode (19ms)
+122ms ║╚Execution stage complete. (48ms)
+123ms ╚Event processed successfully (123ms)
10.3.2021 22.04.41 +838ms
+1ms ╔Received event [Button Soveværelset].button = held with a delay of 67ms
+58ms ║RunTime Analysis CS > 21ms > PS > 7ms > PE > 31ms > CE
+60ms ║Runtime (40194 bytes) successfully initialized in 7ms (v0.3.113.20210203) (58ms)
+61ms ║╔Execution stage started
+69ms ║║Comparison (enum) held gets (string) pushed = false (1ms)
+70ms ║║Cancelling condition #2’s schedules…
+71ms ║║Condition #2 evaluated false (5ms)
+72ms ║║Cancelling condition #1’s schedules…
+73ms ║║Condition group #1 evaluated false (state changed) (8ms)
+79ms ║║Comparison (enum) held gets (string) held = true (1ms)
+81ms ║║Cancelling condition #17’s schedules…
+82ms ║║Condition #17 evaluated true (5ms)
+83ms ║║Cancelling condition #16’s schedules…
+84ms ║║Condition group #16 evaluated true (state changed) (7ms)
+86ms ║║Cancelling statement #18’s schedules…
+187ms ║║Executed virtual command setLocationMode (98ms)
+189ms ║╚Execution stage complete. (128ms)
+191ms ╚Event processed successfully (190ms)
10.3.2021 22.04.11 +792ms
+0ms ╔Received event [Button Soveværelset].button = pushed with a delay of 40ms
+48ms ║RunTime Analysis CS > 18ms > PS > 7ms > PE > 24ms > CE
+51ms ║Runtime (40196 bytes) successfully initialized in 7ms (v0.3.113.20210203) (50ms)
+52ms ║╔Execution stage started
+58ms ║║Comparison (enum) pushed gets (string) pushed = true (0ms)
+60ms ║║Condition #2 evaluated true (3ms)
+61ms ║║Condition group #1 evaluated true (state did not change) (5ms)
+65ms ║║Comparison (integer) 0 is_even = true (1ms)
+66ms ║║Condition #11 evaluated true (4ms)
+67ms ║║Condition group #10 evaluated true (state did not change) (5ms)
+69ms ║║Cancelling statement #13’s schedules…
+84ms ║║Executed physical command [Sengen].setLevel([30]) (10ms)
+85ms ║║Executed [Sengen].setLevel (11ms)
+90ms ║║Executed physical command [Sengen].setColorTemperature([2400]) (3ms)
+91ms ║║Executed [Sengen].setColorTemperature (4ms)
+96ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1
+99ms ║║Executed virtual command [Sengen].setVariable (1ms)
+103ms ║║Comparison (integer) 1 is_odd = true (1ms)
+105ms ║║Condition #22 evaluated true (2ms)
+105ms ║║Condition group #21 evaluated true (state did not change) (4ms)
+107ms ║║Cancelling statement #3’s schedules…
+114ms ║║Skipped execution of physical command [Sengen].off([]) because it would make no change to the device. (4ms)
+114ms ║║Executed [Sengen].off (5ms)
+119ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2
+121ms ║║Executed virtual command [Sengen].setVariable (0ms)
+127ms ║║Comparison (enum) pushed gets (string) held = false (1ms)
+128ms ║║Condition #17 evaluated false (4ms)
+129ms ║║Condition group #16 evaluated false (state did not change) (5ms)
+131ms ║╚Execution stage complete. (80ms)
+132ms ╚Event processed successfully (132ms)
