I am a log time CoRE user but new to webCoRE and not in any way a pro at coding so this is so far an interesting challenge I am enjoying. I have all electric heat w/heat pump. I have 2x pistons to change my honeywell t-stat to Emergency heat and back to normal heat depending on outdoor temps using the $twcweather command as I don’t like the noise my heat pump makes when it gets too cold out, typically around 32F it does not seem to put much if any heat into my home around these temps. I also had similar pistons set up in old CoRE and they behaved the same way. I am planning on moving away from old CoRE solely to webCoRE once I get all my pistions migrated. Thank you for any help on this matter.
At or below 33F, one piston is set to change my t-stat to emerg. heat and not use the heat pump for as long as the temp is at or below 33F. Once outdoor temps get to 34 or higher, the 2nd piston is set to change the t-stat from emerg. heat back to normal heat to use the heat pump.
Both pistons seem to work at the correct temps, but only if I go in to the dashboard and hit the test button for each, depending on temps. it don’t seem like they are ‘polling’ to see what the outside temps are or what my t-stat is set at for comparison automatically.
Below are the upload imgs of both pistons, 1st one is to change to Emerg. heat, 2nd is to change back to heat.
1
2
This is the log to change from heat to emerg heat at desired temp. It returned false, no state change as the temps outside are not in the specified range:
11/15/2019, 1:41:01 PM +691ms
+1ms ╔Received event [Home].test = 1573843261689 with a delay of 2ms
+79ms ║RunTime Analysis CS > 17ms > PS > 48ms > PE > 14ms > CE
+82ms ║Runtime (37535 bytes) successfully initialized in 48ms (v0.3.110.20191009) (79ms)
+195ms ║║Comparison (dynamic) 35 is_less_than_or_equal_to (integer) 33 = false (1ms)
+197ms ║║Condition #2 evaluated false (107ms)
+198ms ║║Condition group #1 evaluated false (state did not change) (109ms)
+203ms ║╚Execution stage complete. (120ms)
+205ms ╚Event processed successfully (204ms)
This is the log of the piston to change from emerg heat back to heat when temp gets above setting. note it only worked once i hit the test button to get the log generated:
11/15/2019, 1:43:49 PM +544ms
+2ms ╔Received event [Climate HVAC T-Stat].thermostatMode = emergency heat with a delay of 52ms
+91ms ║RunTime Analysis CS > 22ms > PS > 58ms > PE > 11ms > CE
+94ms ║Runtime (37586 bytes) successfully initialized in 58ms (v0.3.110.20191009) (91ms)
+145ms ║║Comparison (dynamic) 35 is_greater_than_or_equal_to (integer) 34 = true (1ms)
+147ms ║║Condition #2 evaluated true (47ms)
+151ms ║║Comparison (enum) emergency heat is (string) emergency heat = true (1ms)
+153ms ║║Cancelling condition #3’s schedules…
+154ms ║║Condition #3 evaluated true (5ms)
+155ms ║║Cancelling condition #1’s schedules…
+155ms ║║Condition group #1 evaluated true (state changed) (56ms)
+157ms ║║Cancelling statement #4’s schedules…
+1327ms ║║Executed physical command [Climate HVAC T-Stat].heat() (1166ms)
+1328ms ║║Executed [Climate HVAC T-Stat].heat (1167ms)
+1330ms ║╚Execution stage complete. (1236ms)
+1332ms ╚Event processed successfully (1332ms)
Thanks again for any help.
