I am making a Get request to an endpoint controlling a string of LEDs. To find out the brightness, the endpoint responds with the current brightness value in plain text like “20” for 20%. I cannot for the life of me figure out how to get that to be recognized by my piston. I’ve tried using the $response variable, that just get set to “null” for some reason. There’s no real argument to use in this case. I’m totally stuck. Any help?
Plain Text Response Not Recognized into Response
WCmore
I would start by logging the entire response immediately after the GET request, like this:
Then save, test the piston, and share your log with us so we can see what you are working with
eibyer
My guess, like I mentioned yesterday, is you are getting more than one $response… the last response is probably blank which is what is saved in your variable.
Ryan780
It’s definitely only getting one response. When I send the GET from postman I can see it returns one message and it’s formated as text not JSON. I will try the Log info and post the result.
Ryan780
Well, the Log info worked…this time. I KNOW that I tried that before. Maybe I was missing the $ or something. I dunno. Important thing now is it’s working. Thank you all!!!
