Trying to extract real-time data from a data stream published using GraphQL.
Using HTTP POST to get the current power reading of my Tibber Pulse.
Running HTTP Post with JSON formated like this:
{“query”:"{subscription{liveMeasurement(homeId:“c70dcbe5-4485-4821-933d-a8a86452737b”){power}}}}
should give me the power reading in the $response variable.
Not using all the escape characters () gives an error saying either
“Invalid double quote termination” or
“Variable subscription/liveMeasurement not found”
Sending external web request to: api.tibber.com/v1-beta/gql/subscriptions
+109ms ║║Error executing external web request: java.lang.reflect.UndeclaredThrowableException
7.6.2019, 14:43:47 +293ms
+0ms ╔Received event [Mitt hjem].test = 1559911427292 with a delay of 0ms
+74ms ║RunTime Analysis CS > 27ms > PS > 29ms > PE > 18ms > CE
+77ms ║Runtime (38142 bytes) successfully initialized in 29ms (v0.3.10a.20190223) (75ms)
+88ms ║║Cancelling statement #1’s schedules…
+112ms ║║Sending external web request to: api.tibber.com/v1-beta/gql/subscriptions
+119ms ║║Error executing external web request: java.lang.reflect.UndeclaredThrowableException
+122ms ║║Executed virtual command httpRequest (18ms)
+130ms ║║Executed virtual command setVariable (1ms)
+156ms ║║Executed virtual command sendPushNotification (19ms)
+162ms ║╚Execution stage complete. (83ms)
+164ms ╚Event processed successfully (164ms)
