Can’t seem to get this piston to fire upon “restoring”.
If the assigned plugs have 0W power draw over an extended period of time (indicating a potential failure of the plugged in appliance), then notify me via SMS. If this occurs, and power consumption then returns, notify me of the restoration.
The restoration SMS is not detecting the state change and therefore not firing that portion of the piston when power consumption returns.
2/22/2021, 8:20:59 PM +138ms
+1ms ╔Received event [Home].time = 1614043259802 with a delay of -664ms
+124ms ║RunTime Analysis CS > 58ms > PS > 7ms > PE > 59ms > CE
+126ms ║Runtime (40796 bytes) successfully initialized in 7ms (v0.3.113.20210203) (124ms)
+127ms ║╔Execution stage started
+151ms ║║Comparison (decimal) 107.155 is_equal_to (integer) 0 = false (1ms)
+153ms ║║Comparison (decimal) 100.237 is_equal_to (integer) 0 = false (1ms)
+155ms ║║Condition #3 evaluated false (19ms)
+156ms ║║Condition group #2 evaluated false (state did not change) (20ms)
+158ms ║║Cancelling statement #29’s schedules…
+164ms ║║Calculating (string) Garage freezers are functioning at + (string) Mon, Feb 22 2021 @ 8:20:59 PM EST >> (string) Garage freezers are functioning at Mon, Feb 22 2021 @ 8:20:59 PM EST
+167ms ║║Calculating (string) Garage freezers are functioning at Mon, Feb 22 2021 @ 8:20:59 PM EST + (string) >> (string) Garage freezers are functioning at Mon, Feb 22 2021 @ 8:20:59 PM EST
+169ms ║║Executed virtual command setState (1ms)
+175ms ║║Executed virtual command setVariable (4ms)
+181ms ║║Comparison (string) green changes_away_from (string) red = false (0ms)
+183ms ║║Condition #9 evaluated false (4ms)
+184ms ║║Condition group #8 evaluated false (state did not change) (6ms)
+187ms ║╚Execution stage complete. (59ms)
+188ms ║Setting up scheduled job for Mon, Feb 22 2021 @ 8:36:59 PM EST (in 960s)
+197ms ╚Event processed successfully (197ms)
