Power cycling piston help needed
Hi - I am new to WebCoRE and writing one of my first pistons. I am sure this is a stupid rookie mistake! This is a wall mounted tablet power cycling pistons to cycle the tablets on & off every three hours.
When the piston runs it cycles the power relay on and off approximately once per second. I chanced the ‘wait’ time from 3 hours to 30 seconds to troubleshoot it but it still cycles once per second.
The expected behavior is that the Power control relay turns on for three hours and then off for three hours to ensure the battery is being ‘worked’.
Instead of every three hours, it is cycling every one second.
I think you may have the execution model of webCoRE wrong in your head.
Like any other app in SmartThings, webCoRE is event driven. Pistons are event handlers.
In your case, the piston doesn’t have any explicit trigger conditions to guide it so subscribes to the events of interest to your conditions. It subscribes to switch events for your Tablet Charge switch.
When the switch turns off the piston is fired and runs from the top. It sees the switch is off so turns it on. It then waits for 30 seconds (or whatever), which in practice means it sets a timer for 30 seconds time and exits. If it woke up and continued (that’s covered next) there would be nothing to do anyway as there are no more statements in the flow.
As you have turned on the switch you get another event so the piston fires again. The previous piston has probably entered the wait by now so it can run straight away. It sees the switch isn’t off and invokes some webCoRE magic called the Task Cancellation Policy. That says that as the condition has changed you probably don’t want the old scheduled task and cancels it (that means when the piston wakes up after the thirty seconds timer it immediately exits again, rather than continuing where it left off).
The piston progresses to the else section and as the switch is on it turns it off and starts another wait.
The switch has been turned off so that generates another event and so it continues looping.
Meanwhile a timer mountain will be building up ready to start running 30 seconds (or whatever) later.
If you swapped the position of the wait and turn on/off tasks the piston would probably work OK. A more elegant solution might be to use a ‘timer’ block instead. This would let you create a block saying ‘every three hours …’. WebCoRE also simulates a toggle function so you could simply toggle the switch.
Agree with @orangebucket. I would do something like…
Every 3 hours
  IF Charger is on
    Then turn Charger off
    Else turn Charger on
  END IF
Thanks so much for the guidance. I have re-written the piston and it now works well! This is how it ended up:
Webcore%20Green%20Check%20II
I also like @orangebucket’s suggestion
Every 3 hours
  With Tablet Charge
    Do Toggle
