Webcore has the ability to use the Hub’s power source changing to battery power to trigger pistons but when I create a simple Piston to send a text when changing to battery power it does not fire
simply to trigger my piston upon the Hub power source changing to battery
Piston does not trigger upon the change to battery power but it does trigger if I change the Hub’s power to battery and then test fire the piston
Anyone use this parameter to fire a piston or know enough about WebCore that can help me figure this out?
