Status change to “NOT PRESENT” triggers “PRESENT” trigger
Piston should only trigger when presence sensor arrives at location.
Piston triggers when leaving and arriving. Am I missing something? Am I not understanding the presence triggers correctly?
8/6/2019, 6:39:22 AM +227ms
+1ms ╔Received event [360 David].presence = not present with a delay of 112ms
+80ms ║RunTime Analysis CS > 17ms > PS > 46ms > PE > 16ms > CE
+82ms ║Runtime (41083 bytes) successfully initialized in 46ms (v0.3.10e.20190628) (80ms)
+89ms ║║Comparison (string) :8976d4192664b102e8a7b44e18f56ca8: is_not (string) :d98a1f9ba306055ef1981913525b1827: = true (2ms)
+90ms ║║Condition #8 evaluated true (4ms)
+91ms ║║Condition group #null evaluated true (state did not change) (5ms)
+103ms ║║Comparison (enum) not present changes_to (string) present = false (1ms)
+105ms ║║Cancelling condition #4’s schedules…
+106ms ║║Condition #4 evaluated false (13ms)
+107ms ║║Cancelling condition #1’s schedules…
+107ms ║║Condition group #1 evaluated false (state changed) (14ms)
+109ms ║║Cancelling statement #16’s schedules…
+113ms ║║Executed virtual command setVariable (1ms)
+117ms ║║Calculating (string) 360 David + (string) has Arrived Home! >> (string) 360 David has Arrived Home!
+122ms ║║Executed virtual command sendNotification (2ms)
+124ms ║║Executed virtual command wait (0ms)
+126ms ║║Requesting a wake up for Tue, Aug 6 2019 @ 6:43:22 AM CDT (in 240.0s)
+129ms ║╚Execution stage complete. (46ms)
+131ms ║Setting up scheduled job for Tue, Aug 6 2019 @ 6:43:22 AM CDT (in 239.996s)
+137ms ╚Event processed successfully (137ms)
